A project I just finished. 2 gates, fencing and a sign
发表于 2021-8-31 22:42:03 | 显示全部楼层 |阅读模式
1, 14 foot gate1, 23 foot gate210 feet of welded fence1 address signMiller TrailBlazer 301Miller 12rc feederMiller ShopmasterMiller 22a feederPlasmaCam CNC TableHypertherm 45 cutterDrills, saws, blast cabinets etc.
Reply:one more of the fence lineMiller TrailBlazer 301Miller 12rc feederMiller ShopmasterMiller 22a feederPlasmaCam CNC TableHypertherm 45 cutterDrills, saws, blast cabinets etc.
Reply:Nicely done!  Love to see an arrow straight section of fencing.Miller Dynasty 200DXMiller 252 Miller 250xMiller Syncrowave 250Miller AEAD200 LegendMiller 375 Xtreme plasmaLincoln WeldPak 100Victor O/A
Reply:Super nice job!  Am I correct in assuming the finish is to remain "au naturale"? In my state, that fence would age about 20 years in a year....salt and more salt...POVERTY...is the Mother of InventionMillermatic 211Millermatic 140Miller Thunderbolt XLArcOne 100STS inverter w/TIGThermal Dynamics 38XL Victor Oxy/AcetyleneJancy Slugger Holemaker IIJet 5x6 BandsawNever enough time & sleep.
Reply:In my state, you had better get some paint on it within 100 years or it will discolor.
Reply:Nice ! That's a lot of fence. I like the base plate with all the gussets .
Reply:yeah, I like and promote rust as a finish. I suggest that people spend the money that would go to paint or to powder on thicker metal.Those gussets had to go in cause there was a property line dispute and the hasp side post of that gate had to move. The gate had to be extended 38 inches and I suggested that we do that as a precautionary measure. That gate is already too freakin big. Those gussets are 18 inches tall and go down to a 3/8 plate that is dead nuts flat against the cement I poured for the post and I put 8 1/2 inch redhead fasteners down through the plate into the cement. Those gussets were fun to weld.I was running my Lincoln weldanpower 225 on the CV tap with an LN25 with 045 NR211. I'll tell you what; that is one great welding setup. That wire burns so smooth out of that machine, a monkey could weld with it.I just replaced that weldanpower with a miller TB302. That lincoln  weldanpower 225 on CV mode runs just as smooth as the TB, just with less power.wRMiller TrailBlazer 301Miller 12rc feederMiller ShopmasterMiller 22a feederPlasmaCam CNC TableHypertherm 45 cutterDrills, saws, blast cabinets etc.
Reply:Truly nice work! Fine build.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:god damn that's one straight fence. Impressive.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:As someone who does 100's and 100's of feet of fencing every year,  I'm impressed, its very straight.   Did you do all that Welding in the field? Or did you fab it up in shop? http://www.philswelding.com
GMT+8, 2025-12-30 05:29 , Processed in 0.070547 second(s), 18 queries .
