Project tool box.
发表于 2021-8-31 22:42:02 | 显示全部楼层 |阅读模式
I've been hunting boxes but everything here is high as hell due to shipping and import taxes.I'm not paying a grand for a damn roller cabinet.Especially since they're all jucking funk .Here's the plan.2) Sheets of 16 gauge black iron(drawers). $ 852) Lenghts of 3/4 angle $ 161) 2-3 hours in my buddies shop on the finger brake. $20 bottle of Flor de Cana.2) Lengths of 1x2x1/8 wall black tube. $ 281) Handful of R45. Too damn windy to MIG this time of year. Torch is more fun than stick. Purtier in the hands of a Drunken Torch God 1) Gallon of etching primer.$501) Gallon of red urethane ( Lincoln code). $75-$802) Sheets of Diamond plate mirror aluminio. $1803) 36 feet of 3/8 x 4" cocobolo. $ 0 4) ARSA rodines ?? Chit. Swivel thingies with 5" wheels  CASTORS ! Plan. 12/ 2 inch deep 28 x 20 drawer bodies.6 per sheet.1 x 2 frame laid flat.1" side looking at you from the front.4" Highly figured cocobolo drawer fronts.Routed 5 inch wide center section for pulling.Angles screwed to inside for the drawers to slide on.Left over 3/4 wide 1/4 thick polymer riveted to the angles.( Left over from airboat build). Slippery a a nun in heat  No I aint buying ball bearing crap.Diamond plate inset and screwed to angles, sides and back.TotalW=30.5 H = 59 3/4 ( includes castors)D= 21Cost / Right around $500. Plus alcohol.  Ok. $600Brake work to commence Thursday.I know. PICTUREZZZ !Here's the general shapeBubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:You can usually pick up snappy roll cabs on CL for $500
Reply:walker, he's in Costa RicaBurpee, looking forward to your build.
Reply:Me too. WARNING: Don't get Dengue.............Postponed. I took the airboat out without DEET. WHEEEEEEEW.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
GMT+8, 2025-12-30 05:39 , Processed in 0.188561 second(s), 18 queries .
