Inexpensive spoolgun options
发表于 2021-8-31 15:02:06 | 显示全部楼层 |阅读模式
I have A millermatic 180, I have a couple of small aluminum repairs to perform Are there any less expensive options for spool guns compatible with my welderThickest ever would be an aluminum intake manifold Thank youScottMillermatic 180
Reply:Try this one https://www.ebay.com/itm/200A-MIG-We...-127632-2357-0Dave  Originally Posted by scott657I have A millermatic 180, I have a couple of small aluminum repairs to perform Are there any less expensive options for spool guns compatible with my welderThickest ever would be an aluminum intake manifold Thank you
Reply:Here's a Miller spool gun chart. Looks like you need a Spoolmate 100 but need to check your serial number (see last link posted below). If your machine is older contact Miller to see if a spool gun can be hooked up. I don't know if I'd try to adapt a cheaper aftermarket spool gun.https://www.millerwelds.com/support/...n-hookup-charthttps://www.millerwelds.com/-/media/...0--english.pdfhttps://store.cyberweld.com/sp100migsp.htmlLast edited by Welder Dave; 07-13-2021 at 01:15 PM.
GMT+8, 2025-12-18 16:08 , Processed in 0.090136 second(s), 18 queries .
