Lincoln 225 AC/DC on a 220v line?
发表于 2021-8-31 22:41:59 | 显示全部楼层 |阅读模式
Will a Lincoln 225 run on a 220v line with a 50 amp breaker? The manual states that the input or power cord will be attached for Lincoln welders that run on anything under 250v but it doesn't specifically say 220...
Reply:Any voltage 208/260 ok
Reply:Yeah, they're just saying that larger machines may not always be factory equipped with a power cord.You'll have no issues with that machine on a 50 amp breaker. Just hook it up and start welding.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:That's great. Thank you both.
Reply:Yep I run mine on a 50 amp breaker I also have a 100 foot extension 6-3 that can handle full power with no trouble.Lincoln A/C 225Everlast P/A 200
Reply:Originally Posted by M J MauerYep I run mine on a 50 amp breaker I also have a 100 foot extension 6-3 that can handle full power with no trouble.
Reply:My 220 volt line measures 242 volts. I have used my Lincoln 225 on a 40 amp fused line for 45 years, dont fuss.
GMT+8, 2025-12-30 08:01 , Processed in 0.101680 second(s), 18 queries .
