Amber lens
发表于 2021-8-31 22:41:54 | 显示全部楼层 |阅读模式
I have a question. Are amber lenses the same as gold lenses? I heard a shade in gold is the equivalent to one shade lighter in green. Is this true? Where do you find these? Does brand matter? If so how? Thanks for the info.2 invision 456 mp, 456 pheonix, 3 hypertherm 1250, Hypertherm 45,Dynasty 200dx, Millermatic 210 w/ spoolgun, Bobcat 250, 12vs extreme, slugger dry cut saw, slugger mag drill, O/A rig, Piles of tools
Reply:No.  Gold lenses are fixed shade lenses with a coating of gold.  Amber lenses can be either fixed shade or auto, and have a somewhat similar shade of puddle to a gold lens, but most think that the clarity of a fixed gold lens is about as good as you can get.  The auto darkening amber lenses are chosen by some that need the utility of an auto darkening but do not like the greenish tint of many auto darkening lenses.  The high end Jackson Nexgen lenses have an amber puddle color.If you're looking for a gold lens, the Phillips Safety Shott glass coated gold lenses are very clear; you can also get plastic gold coated lenses at almost any welding supplier, but they are more succeptable to scratching and not quite as clear...
Reply:Yeah, I would not say gold has a lighter shade, but I would say they show a broader color spectrum than the others.What I will say I that my Shott gold #10 is startlingly bright and clear. And stay away from Weldmark brand gold filters.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I got a cheap Hobart gold from Northern Tool. Best purchase (almost) ever. I can't stand the green lenses.They aren't very expensive. Mine was only around $5, but they can be had for anywhere between 5-20$.You can order them online from Phillips Safety I believe.
Reply:All the fellas above nailed it, the glass gold plated lenses from athermal sold by Philips Safety. I have one in a shade 10 and plan to buy another in a shade 12.Ranger 250 thick stuffHobart Handler 140 not thick stuffthe pane and oxy setup
Reply:Another +1 for the Philips gold coated Glass.  I tried a few different brand plastic ones and they all had some sort of internal reflection causing me to see a multiple tungstens.  The Philips isn't as amber as the plastics but there is no contest that its better.There are a few SpeedGlas helmets and a Jackson NexGen in the lab at school and I usually pick up my #10 gold from Philips when I'm TIGing.~Alex
Reply:I find the multiple view of tungstens or wire is usually from the cover lens being to far from the tinted one, especially on a helmet with a flip up safety lens. I used to have a expensive glass gold lens, but havent seen it for a while.  You have to make sure the cover is always on good, spatter will stick to glass, but not as much on plastic.
Reply:I tried the gold plated plastic lens by itsself in the helmet and had the same issue, passed it off to the boss and he saw the same thing.  Could have been a bad batch.   I am very happy with my gold coated glass lens from Philips.  The plastic ones were "usable" but the reflections did get annoying.~Alex
Reply:+10000 to the phillips safety german high quality glass gold lens hands down over any auto dark for clarity any day of the weekMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Originally Posted by WookieWelding+10000 to the phillips safety german high quality glass gold lens hands down over any auto dark for clarity any day of the week
Reply:I need to try one!
GMT+8, 2025-12-30 08:00 , Processed in 0.069721 second(s), 18 queries .
