Hey look I can weld something besides Aluminum......lol
发表于 2021-8-31 22:41:52 | 显示全部楼层 |阅读模式
http://img.photobucket.com/albums/v9...psd6b71016.jpghttp://img.photobucket.com/albums/v9...ps3f73de57.jpg  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:What are they?
Reply:Looks really nice I also wonder what the heck they are??Dave J.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:They look nice.  I think for all those pieces I would have been trying to make some kind of positioner to do them.
Reply:The print says that it is a motor mount assembly.    I dont know for what but that is the what the print says.Lincoln AC225 Stick WelderSolar 2175 MIG Welder
Reply:So what's with the short runs? You need a positioner!I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by jamesyarbroughWhat are they?
Reply:I stopped asking what stuff was years ago.....If it said motor mount then thats news to me?I wish they were 304 so I could spin them in a rotary and just fuse the tube to the plate would be fast and could make my wages easier......BUT their 316 and I have to apply fillerLast edited by B_C; 09-09-2013 at 09:58 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:Originally Posted by B_CI wish they were 304 so I could spin them in a rotary and just fuse the tube to the plate would be fast and could make my wages easier......BUT their 316 and I have to apply filler
Reply:Originally Posted by B_CI stopped asking what stuff was years ago.....If it said motor mount then thats news to me?I wish they were 304 so I could spin them in a rotary and just fuse the tube to the plate would be fast and could make my wages easier......BUT their 316 and I have to apply filler
Reply:304-316, 6 in one half dozen in the other.
Reply:That's a funny looking motor mount.Where are the close up shots?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I read your print!Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Yeah, were these really designed in 1976?
Reply:Originally Posted by gimpyrobbYeah, were these really designed in 1976?
Reply:Hmmmmmmm now you guys have me thinking.......all these years I was under the impression 316 would crack unless you added filler if you fused it?  wow this opens up a whole new deal with these parts  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:I screwed up and left links to the other shots......  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:B_C, I've got my Dynasty 350 up and running now and so far I'm very pleased.I've been welding 1/2" diameter X .035" wall 4130 tubing for some aircraft weldments and it has a great ability for low amperage DC welding.Equally, on 1mm sheet Aluminium where I had to weld some bosses to the sheet and screwing the AC Hertz way up to get the tiny welds required also was better success than I anticipated.I haven't explored the EN/EP side of things yet but I'm sure I'll get around to it.Regards Andrew from Oz.
Reply:As far as I know you can fusion weld 316 just like 304. The only issue would be if the prints called out a given size reinforcement on the weld. I still can't see a reason why you couldn't add filler while running the bead on the positioner. You obviously have the skills to feed filler on alum, so I can't see adding filler on stainless being a huge deal. If anything I'd have more issues getting used to running the positioner since I don't have one..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by awill4x4B_C, I've got my Dynasty 350 up and running now and so far I'm very pleased.I've been welding 1/2" diameter X .035" wall 4130 tubing for some aircraft weldments and it has a great ability for low amperage DC welding.Equally, on 1mm sheet Aluminium where I had to weld some bosses to the sheet and screwing the AC Hertz way up to get the tiny welds required also was better success than I anticipated.I haven't explored the EN/EP side of things yet but I'm sure I'll get around to it.Regards Andrew from Oz.
Reply:Originally Posted by DSWAs far as I know you can fusion weld 316 just like 304. The only issue would be if the prints called out a given size reinforcement on the weld. I still can't see a reason why you couldn't add filler while running the bead on the positioner. You obviously have the skills to feed filler on alum, so I can't see adding filler on stainless being a huge deal. If anything I'd have more issues getting used to running the positioner since I don't have one.
Reply:I wish I would have tried just one part before I was done with the run......maybe 120 amps and set the turn table on haul ***......all this time and I didnt think 316 would fuse without crack issues.....  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:I fusion weld a ton of stuff! 316, 304, 18-8, 17-4, 15-5, without issue. We fusion weld at work up to 1k PSI pressure containment and a lot of times dissimilar metals at that.  I vote ROTORY TABLE!  We use Weldlogic AWS 150s for the round stuff,  Everything else I free hand.(Home)Miller Maxstar 152 (sold)MM211/spool gunLincoln AC 225C(Work)Dynasty 350Powcon 300STLincoln SP-175TWeldlodgic AWS150sWeldlodgic AWS300Custom Resistance seam weldersCambridge Vacuum EB weldersI smell something burning.
Reply:Cool thanks I have another batch coming soon and will give it a try........  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
Reply:I fuse corners on 316 sinks for laboratories all the time, you'll be fine. And as usual, exceptional work. Thanks for sharing.
GMT+8, 2025-12-30 06:19 , Processed in 0.074480 second(s), 18 queries .
