Magnum MMG35FH generator
发表于 2021-8-31 22:41:51 | 显示全部楼层 |阅读模式
2006 model Magnum MMG35FH generator, it was used as a backup generator for a local business. It has 28hrs on the unit and also has a Optima Battery. Just had the oil and filters changed, the antifreeze was just tested also. It can be used as a trailer mounted unit or can be detached as a skid mount also. I will deliver it up to 100miles free of charge. Attached Images
Reply:Spec's and $$ please.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-30 06:19 , Processed in 0.091334 second(s), 18 queries .
