dynasty 200 complete package
发表于 2021-8-31 22:41:51 | 显示全部楼层 |阅读模式
dynasty 200 complete package so i am looking for a tig package that i could run off of my bobcat 225 nt.   I would also like to use it  in the shop.   Is the dynasty feasable in doing this.  the complete package comes with all needed and a water cooler and water cooler compatable tig torch.  just wondering   oh yeah i know i can do non critical tig with my bobcat but am looking for a good machine to utilize more in the shop but want it to work in the field when i need it to.www.burdettenetworks.com
Reply:Your Bobcat's generator will power a Dynasty 200 tig machine no problem.  Using your Bobcat to power the Dynasty is a much better solution for tig welding than buying the HF251D1 with contactor to tig directly off the Bobcat.I would go with an air cooled torch for the mobile setup and use a watercooled torch in the shop.  The less extra stuff you have to lug around on the job site and store on the truck the easier it is to get the job done and get out of there and on to the next job.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:desert rider-   Thanks for the info.  If you look on cyberweld.com they sell a all inclusive package with cart rigged for the 200 its cooler unit and bottle storage.  I was considering getting this for easy movement.  I will be using an enclosed trailer for most of my tool storage and moving to and from jobsite so would be easy for loading and unloading since it has a fold down ramp.    what would you think about utilizing a heavy 220 volt extension cord from the bobcat to the dynasty to enable me to move the dynasty closer to the work and not have to have the trailer right there?www.burdettenetworks.com
Reply:220V extension cord is the way to go.This machine is very portable if you put it on a cart, and the 10 gauge extension cord will cost you much less per foot than welding cable.
Reply:The extension cord is great.  I carry 100' of 220v extension cord on the truck for just that sort of situation.  Carrying the Dynasty by itself with an air cooled torch would still be alot more convenient than having to roll out a whole cart.  Not all jobs will be on a nice flat surface to roll a cart through.  You may be going up or down stairs or up a ladder, etc.   I would buy the watercooled cart package, and leave the cart and watercooler at home and just take the Dynasty and an air cooled torch out on mobile jobs.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Depends on how you set your cart up.I mounted my Dynasty vertically on a hand truck, with the Argon next to it in hoops on the side.  It can be laid down horizontally in a truck, but I keep it vertical just about all the time.It takes up almost no floor space, and travels over anything (stairs included).  Ladders, not so much, but this machine is a bit much for ladder travel anyway (especially if you take argon along).Vertically, it actually runs a little cooler (air convection cools the machine keeping the fan from kicking in as soon), BUT YOU MUST PROTECT THE TOP FROM GRINDING DUST.That stuff is conductive.  I once thought it killed my machine when the HF didn't work.  It was solved by blowing out with compressed air.  I'm guessing the dust shorted something, but thankfully there was no permanent damage.  I just use a cloth cover now.
Reply:Thanks for the advice guys I found the whole package for around 4500 with cooler and allwww.burdettenetworks.com
Reply:Check out cyberweld.com. Free shipping and I think they have it for around 4300.
Reply:thanks spaulding i have bought other things from them in the past and the delivery is free and fast.  I hate to not support my local guy but he just cant compete especially on miller stuff for whatever reason.www.burdettenetworks.com
Reply:I agree with that. Even if it is a few hundred dolars more I like to support my local guy as well. cheers
GMT+8, 2025-12-30 08:00 , Processed in 0.080131 second(s), 18 queries .
