Sunday Afternoon Screen Play
发表于 2021-8-31 22:41:46 | 显示全部楼层 |阅读模式
Working on a mobile industrial fire apparatus foam system refurb job and the 4" flanged suction strainer installed 14 years ago was equipped with an 1/8" perforation screen from the factory.  Some time after that it was learned the foam pump manufacturer recommends a 1/4" perforation screen for the application.So, today I made a new screen from a small sheet of 1/4" perforated SS (didn't measure it but guessing 16ga.).  TIG'd it up with the Syncrowave 180 SD using 1/16" 2% Thoriated, amps set to max using the peddle, argon set a little high at 12cfh and .035" 316 MIG wire for filler when needed.  Mostly tried to just wash the puddle from the top piece down to the bottom and wound up burning thru in a few places but I have far more holding than the 9 small spot welds on the original so I don't see it going anywhere.The remaining piece of material following cutting the section required for the new screen.  Positive displacement timed rotor foam pump is red device in the background.One of the two hose clamps used to hold the hand formed screen to the correct dimension over the male pilot end cap for welding.  You can see a couple of the burn thru spots.The tacks on the leading edge.The new screen compared to the original and ready for installation.Thanks for looking.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Looks better than factory made to me. Nice work and use of the old noodle.Sent from my SAMSUNG-SGH-I497 using TapatalkGravelThe difference between theory and practice is that in theory there is no difference.
Reply:Nice work duane it will probably work better than the stock oneBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:Nice job - looks like it could be tricky to weld.  Kind of an odd project to be working on - how did you end up getting it?Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Originally Posted by MinnesotaDaveKind of an odd project to be working on - how did you end up getting it?
Reply:Looks good Duane! What type of industry are they used in? Looks like something for a cooling tower of some sort. Oops Just seen the last post.Miller 250DX HTP 221 DV AC/DCHenrob O-A Miller 180 MigMiller 150 Inverter   Hobart 10,000 Welder-Generator   Have a good day!!!
Reply:Looks great as usual!Will there be enough pulsation to make those little tails where you burned through wave back and forthuntil they break off and go into the pump?Rex
Reply:Originally Posted by duaneb55It's a result of my background.  I worked for a major fire apparatus manufacturer for 11 years before going to work for my previous employer of 14 years that manufactures the foam system the truck is equipped with.In fact, I installed this system in this truck in '98 which is how I was introduced to my last employer where I eventually became manager of the product line.  The person that contacted me to do the work also worked for the same company before becoming the manager of the contract fire fighting company he works for now which is how he knew I know these systems.
Reply:Originally Posted by rexcormackLooks great as usual!Will there be enough pulsation to make those little tails where you burned through wave back and forthuntil they break off and go into the pump?Rex
GMT+8, 2025-12-30 06:18 , Processed in 0.109735 second(s), 18 queries .
