Aluminum boat fix
发表于 2021-8-31 22:41:45 | 显示全部楼层 |阅读模式
I know this is a completely stupid question but i have a 12' aluminum flat bottom river boat that I need to mount a couple of seats onto the aluminum benches. I have a wire welder but only have flux core wire on the spool. If I set this to it's lowest setting, could a couple of brackets be welded onto the bench seats inside the boat to mount my swivel seats onto ?
Reply:Your asking if you can weld aluminum with fcaw wire?Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Originally Posted by rico334I know this is a completely stupid question but i have a 12' aluminum flat bottom river boat that I need to mount a couple of seats onto the aluminum benches. I have a wire welder but only have flux core wire on the spool. If I set this to it's lowest setting, could a couple of brackets be welded onto the bench seats inside the boat to mount my swivel seats onto ?
Reply:Ok, well I didn't figure it would work, just thought I would ask before I tried it and made a huge mess out of things.....
Reply:Hey.... good link there Sandy... That will fix the problems... THANK YOU
GMT+8, 2025-12-30 06:18 , Processed in 0.096257 second(s), 18 queries .
