Welding helmet
发表于 2021-8-31 22:41:43 | 显示全部楼层 |阅读模式
I'm in the prosess of buying a welding helmet and want to know what is the key points when buying a helmet? Better have it and not use it than need it and don't have it.https://www.youtube.com/channel/UCpr...4EqsJun_bjErpA
Reply:Buy what you think you need. There are tons of threads on welding hoods. Find one that's comfortable to you and has the features you like.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:First rule in my shop is you can"t use mine, so you better have a backup hood or you clean the toilets for the rest of the day.Second is clarity. Fixed shade seems to deliver clarity for old guys like me.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I'm not a pro only a "weekend welder".How important is the amount of sensors and viewing size?Better have it and not use it than need it and don't have it.https://www.youtube.com/channel/UCpr...4EqsJun_bjErpA
Reply:Any one sensor will activate the filter.Having more becomes important when welding in an area where the sensor may get blocked. Many welders like large viewing areas ,but when you weld your only looking at a small spot.Large windows and more sensors won't make you a better welder.Comfortable good fitting head gear is more important,try on a hood before you buy it.
Reply:Ive got a Miller "pro Hobbie" my self. Its a auto darking unit and seems to work great. Ive got no complaints. A bit pricey up front, but compared to a fixed shade its the cats meow.Pidge
Reply:It also depends on the process.  I got away with a HF for around 10 months while I had my MIG, but when I got my TIG welder the hood wasn't big enough so I was getting sunburned.  The 2 sensors on the HF were not enough and when TIG welding around corners I would get flashed.  Moved to a Lincoln 3350 and all is good now.Syncrowave 210HH140Victor O/A
Reply:Tx for all the info.Will make a informed  decision.Better have it and not use it than need it and don't have it.https://www.youtube.com/channel/UCpr...4EqsJun_bjErpA
Reply:Ihave a Miller Digital Performance. It has three arc sensors and a Cut and Grind Mode. It does everything i need it to do and it is VERY clear.Miller Dialarc 250Miller Bobcat 225Hobart Oxy/FuelCouple of Dewalt and Milwaukee GrindersJET Bandsaw and Drill Press
Reply:VIEWING AREA/size of yer window...Viking 3350 is amazing, does it allSent from my iPhone using Tapatalk
Reply:Keep in mind that some hoods use a non standard size lens and that a replacement lens can get expensive or hard to find.
Reply:Yeah I guess I hadn't thought about it but it does come with 2 or 3 extraRespect Your Welders
Reply:I have a HF hood. Works well for  what I do. Can't grind with it and the way I have it set it will darken with the orange ball at the end of the mig gun. Just do hobby/farm welding with it. The blue flame adjustable auto dark.
Reply:Well bought/win one on fleabay that I put a bid on for €645-13 shade100x53mm viewing4 sensorWill see how good it is when it comes next week.Why would I buy a thing for a tenner if I can make it for fifty.https://www.youtube.com/channel/UCpr...4EqsJun_bjErpA
Reply:[QUOTE=Dallasnewb;5531381]Yeah I guess I hadn't thought about it but it does come with 2 or 3 extraWhat size are they and what do they cost? Are they readily available? Not trying to kick your donkey but I hear some of the prices guys are paying for non standard size lenses and it gets a little pricey for a full time welder. I have also heard that some hoods on the market take a different inner and outer lens. All my hoods are of the two standard sizes and I pay 19 cents each delivered for the small lenses when purchased in bulk making a lens change out 38 cents. Would love to hear what others are paying for replacement lenses in these new hoods.
GMT+8, 2025-12-30 06:18 , Processed in 0.111350 second(s), 18 queries .
