What Kind Of Old Welder Is This?
发表于 2021-8-31 22:41:43 | 显示全部楼层 |阅读模式
I picked this up today for $40 bucks from the local scrap man. Still works good and laid a good bead, It is an old 400 amp single phase welder, has crank on top, leads on bottom for high and low settings. Does anybody have one of these? or know what it is? It weighs about 300 LBS. I got it as you see it. Thanks Attached Images
Reply:Looks like a 'reassigned' transformer off a utility pole.Westinghouse maybe?  You've got way more than $40 worth of leads there.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I know, He took my $40 and my scrap steel pile(forgot that part) But still it was not that much(4-500 lbs). The stinkin thing works! Thanks
Reply:Originally Posted by duaneb55Looks like a 'reassigned' transformer off a utility pole.
Reply:Looks like a machine I used to run years ago, if its the same it is a AC machine only, I used to run 1/4" 7018 with it at about 300 amps if I remember right.I always tried to work with the oldest hand on the job to gain knowlege but now I can't find any.
Reply:The crank handle up top looks nicer than the one on my mill..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Yea, I burned a 5/32 7018 on about 300 amps, The rod was smoking at the bottom. Ac only machine.
Reply:Good Catch!Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:NEVER seen anything like that. not bad for $40 Did you get the other 2 welder's going?
Reply:Originally Posted by BruceGood Catch!
Reply:Originally Posted by bigduckNEVER seen anything like that. not bad for $40 Did you get the other 2 welder's going?
Reply:Originally Posted by jreynoldsweldingThanks, Bruce. Maybe one day I'll Check out that old project your working on.
Reply:Glad to hear about the ranger.Allway's good to have a few part's extra
Reply:Nice find man! It would be great if you restore it.Midwest Metal ProductsMetal Wire Forming Fan Guards Delta-Larm
GMT+8, 2025-12-30 07:54 , Processed in 0.111818 second(s), 18 queries .
