torch and adapter.
发表于 2021-8-31 22:41:42 | 显示全部楼层 |阅读模式
so i finally found an adapter so i can run a water cooled torch on my Lincoln 175 TIG. My main reason for wanting to upgrade to a torch like the WP20, are the much more flexible/lighter hoses leading to the torch. the factory cables are heavy and VERY stiff wich often cause problems while welding...my question is, can i run a water cooled torch without actually being water cooled. basically, get the adapter and the WP20, and just tape up the 2 water lines for now. I plan on making my own water cooler. So until i gather my parts and plans.... would it harm the torch to run it air cooled and not water cooled?heres the part number for the adpater: 195 380what a good place to purchase the adapter and torch also?Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:You can run a water cooled torch on your Lincoln tig machine with an adaptor.  However, you can not run a water cooled torch without a water cooler.  That's a real good way to smoke a perfectly good torch.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Some run a water cooled torch by hooking up to a faucet and dumping the "waste" down the drain. I wouldn't recomend that if you are where your stuff can freeze however.As DR said, if you have a watercooled torch, it needs the water or you can probably expect to get a new one..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by DesertRider33You can run a water cooled torch on your Lincoln tig machine with an adaptor.  However, you can not run a water cooled torch without a water cooler.  That's a real good way to smoke a perfectly good torch.
Reply:you need this adaptor http://www.arc-zone.com/index.php?ma...products_id=47Synchowave 180SD  Bernard 3500SS water coolerMillermatic 200Parker Plasma Tec 40dvOperating Engineers Local 12
Reply:You need the adaptor.  Do you have something against adaptors?  Just get the adaptor... and a water cooler.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:There are a few things you have to do, in welding.  JGSMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFCand Shielding Gases.  There all here. :
Reply:Originally Posted by DesertRider33You need the adaptor.  Do you have something against adaptors?  Just get the adaptor... and a water cooler.
Reply:Originally Posted by BruceTSyou need this adaptor http://www.arc-zone.com/index.php?ma...products_id=47
GMT+8, 2025-12-30 07:51 , Processed in 0.112588 second(s), 18 queries .
