Machining Lubricant/Coolant
发表于 2021-8-31 22:41:42 | 显示全部楼层 |阅读模式
I need lubricant for simple home machining activities. Industrial products come in one and 55 gal sizes. Where can I get a small quantity of soluble oil for use at home?Or is there a home brew recipe that I can create myself?Cheers!
Reply:misread the postLast edited by tresi; 01-07-2010 at 09:38 PM.Tough as nails and damn near as smart
Reply:I'd suggest you try MSC.http://www1.mscdirect.com/CGI/GSDRVS...00000122107480.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Find a machine shop that buys in bulk.  Offer to purchase a small quantity.  Maybe.....My name's not Jim....
Reply:www.use-enco.com has some.This one was recommended to me:http://www.use-enco.com/CGI/INSRIT?P...&PMPXNO=946817I don't think you'll find much in quantities less than 1 gal.Lincoln SA200, HH135, Lencospot, HF80 Inverter, Rockwell 11x35 lathe, HF drill mill, Kama 554 tractor w/ FEL & BH, Belarus 250AS, lot's of Chinese tools
Reply:You have an Airgas nearby?  They sell soluble oil by the quart for their Hougen mag base drills with annular cutters.
Reply:never tried it myself but....coconut oilhttp://www.jeepforum.com/forum/f37/d...ut-oil-699831/
Reply:yes enco allso grizzle
Reply:wd-40 in a one gal. can at any home inprovement store.mobil makes a water soluble cutting oil in 1 gal jug mix it 20 to 1 last me about 4 yearsgraingers enco msc travers mcmaster carr.Daye
Reply:one more up for WD40
Reply:I have used "Kroil."  Comes in an orange can, with black print.  I am unsure as to how soluble it is.  They sure are proud of it, though.-Rhyno07 Fowler 200D65 RedFace04 Miller TB 302, 22hpMiller 12RCMiller HF 251-1Lincoln SP135HyperTherm PM 380and a few others... Originally Posted by RhynoBut, if I "all of a sudden disappear....  ...." hopefully I didn't suffer too much....
Reply:go to the local oil supplier.  cheaper than most anywhere else you will buy it.  Doesnt matter what brand.  You can buy it in 5 gallon buckets.  Because I have an issue sometimes with heat in the shop, I use soluble cutting/grinding fluid, mixed with RV antifreeze and water.  1 or 2 parts oil, mixed with a 50/50 mix of antifreeze/water.All of your lubrication needs will be met at your oil supplier.  cc
Reply:Milwaukee Hawg Wash, It comes in a quart and makes over a gallon. http://www.toolup.com/milwaukee/49-3...kee+49-32-0081Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Brilliant!!!Just the ticket! Originally Posted by TozziWeldingMilwaukee Hawg Wash, It comes in a quart and makes over a gallon. http://www.toolup.com/milwaukee/49-3...kee+49-32-0081
GMT+8, 2025-12-30 07:57 , Processed in 0.160491 second(s), 18 queries .
