linde migmaster 160
发表于 2021-8-31 22:41:40 | 显示全部楼层 |阅读模式
Hello fellow welders, Just joined this forum. A few months ago I was given a Linde Migmaster 160. the rectifier is out of it and I have been trying without any luck finding one. If anyone has any ideas this would be appreciated. Thanks everyone inadvance with your help. Todd
Reply:You could check with member 7A749 as he's been restoring machines for a long time and may be able to help or point you in the right direction.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I think that Esab now owns the assets of what used to be Linde Corporation/ L Tec.  You might also try Digi-Key if you know the requirements of what the rectifier needs to be as that may be quite a bit cheaper than trying to get a factory part that may or may not still be in circulation.
GMT+8, 2025-12-30 06:18 , Processed in 0.096916 second(s), 18 queries .
