Messing around w/ 7018
发表于 2021-8-31 22:41:39 | 显示全部楼层 |阅读模式
was cleaning up the shed and decided to mess around with some 7018. The plate is a 1/4 T joint. Thermal Arc 186, 5/32 7018 (Hobart AC rod), DCEP 155 amps, hot start at 50.Last edited by yammahoppy; 09-27-2013 at 08:30 PM.
Reply:You'll need another pass on top of that one. Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:It looks like your electrode angle changed half way across your weld. You can see a we bit of undercut on the vertical piece the first half of your weld. Then you changed your electrode angle and maybe your travel speed a bit. and the undercut went away. That's a good sign when you are able to recognize an issue then make a change to correct it when stick welding.
Reply:Originally Posted by CEPYou'll need another pass on top of that one.
GMT+8, 2025-12-30 06:18 , Processed in 0.179924 second(s), 18 queries .
