This welder is brand new , never been used Brand Snap-onWeight 195 lbCountry Of Origin USAInput Voltage 120VInput Current 20/30AOutput Current 30-140ADuty Cycle 100% @ 140 Amps140 amp output @ 100% duty cycle, 120VAC, 50 Hz/60 Hz. Use for continuous, spot, or stitch welding using .023" through .035" wire. Welds up to 1/4" in a single pass. For use in auto body collision repair, automotive repair shops, maintenance and manufacturing applications and custom fabrication shops where voltage input is limited to 120V. Highest duty cycle 120V MIG welder available. Includes cylinder rack, MIG torch with 10' cable, 15' feeder cable and 20' power input cable. The internals are all copper (it really does weigh alot) mot other companys have been using aluminum for most of the internals which saves weight but causes more resistanceThis includesThe weldermig gunground cableregulator for the gas bottle1 spool of wireand a small bag of consumables for the mig gunthe tig setup is with itwhich is the hoses and the torcha few cups and contacts$3200 obo located in fort worth texaswill deliver within 150 mile for the cost of fuel
Reply:That's an expensive 140 amps! Have you looked at what a comparable size name brand machine runs?
Reply:Typical over-pricing for "off the truck" "pay the man in weekly payments". Always WAYYYYY over -priced. get a Hobart Handler 140 for about $500.00, and have the best 140 out there today!My first Plasma Cutter was a used Blue Point (Snap On), and I had to call Snap On's "customer Service" to find out how to get it started (it had a unique "push the spring-loaded tip" firing drill). It was the rudest, most arrogant telephone rep I have ever encountered for anything! I listed it back on Ebay the next day, and sold it."Good Enough Never Is"MIller AC/DC ThunderboltHobart HH180, 125EZRiland Cut 40 Plasma oxy/act outfitTons of "stuff", all treasures to me!
Reply:Must be a typoGordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
Reply:Nope,A set of straight wrenches can be 700 bucks or more. Think a Snap On welder is going to be at that price. Snap on out sources their equipment. I would say that it probably is made by one of the three or four majors.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by lugweldNope,A set of straight wrenches can be 700 bucks or more. Think a Snap On welder is going to be at that price. Snap on out sources their equipment. I would say that it probably is made by one of the three or four majors.
Reply:From the on line snapon tool catalog!That welder retails for $2995.00, plus add $595.00 for the tig setup!It looks like a Schumacher welder.Heres a link:http://buy1.snapon.com/catalog/item....re&dir=catalog#1. If you don't like what I wrote, or if it offends you, then don't read it!#2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**!
Reply:Yea it is a high price but i bought it because of the great things i have heard about it, i have a millermatic 175 and have had many problems with it, and it was the cheapest mig tig combo i could find
Reply:Schumacher isn't exactly the king of welders. Its just above Harbor Freight in my book. They should stick to battery chargers.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Holy Sh*t. You could get a brand new Lincoln Power MIG 350 MP for only $250 more.You could get a brand new ESAB multimaster 260 for $400 less. Ouch.....
Reply:Not to mention unavailabilty of consumables. |
