my next project
发表于 2021-8-31 22:41:33 | 显示全部楼层 |阅读模式
I bought this little trailer for next to nothing back in the summer. it is mainly constructed of wood, as in the underside except for the tongue and the axle is all wood, the frame is 3 4x4s length wise and the tongue and axle are bolted to them. I will post more pics when I get it thawed out and turned up on its side.Lincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
Reply:Aw leave it that way and just ad some aluminum rims.:-)
Reply:Looks like a great starting point. I just finished a project 99% the same. Complete rebuilt. Had a ton of fun doing it too. What are your plans? Make it all metal? I will highly advise you to take your time to align the axle on it. I spend 3 days getting it just right on mine. Hope to see more!I could add a photo of my trailer if you want me too. You could steal some ideas.
Reply:well I got it almost all apart. about the only thing left to do is take the axle off. here are some more pics. basically all I have to work with is a tongue ,an axle and some fendersLincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
Reply:Judging by that first pic looks like a good snow hauler!Miller trailblazer301gLincoln sa200Miller251Miller spectrum 625Victor oxy-acc2002 Chevy duramax 3500 dually 4x4
Reply:Originally Posted by BlackbeardJudging by that first pic looks like a good snow hauler!
Reply:Are you planning on making a fully welded frame?
Reply:i was thinkin a fully welded frame from maybe 2x4 tubing, also thought about makin it a deck over to gain a little width. I might be ahead to just scrap what I got here and buy a tandem axle car trailer that needs some work and have a better starting base.Lincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
Reply:You could do that. But, a little trailer come in handy lots!
Reply:I have one similar. One of the farmers cut up an old car and used part of the frame for the base and the steering axle with the tie rods welded so the wheels stay straight.  I put 2x6s for the deck. Bout 5 wide and 9 long. Its excellent for cleaning out the barn, hauling the generator, tools, cow dooky. Just the right size for the 4 wheeler.  Handy.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:Yikes......Is that thing unsprung?   I don't see a whole lot salvageable there, except for maybe the wheels...   Please keep safety priority #1!
Reply:safety is the reason I tore it apart, yes it is unsprung, and the wood was about rotted in places. yea not much salvageable but I got lots of scrap stock.Lincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
Reply:I wouldn't haul that down the road but I would use it behind a tractor or quad for some farm/ranch use.Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:I pulled it home from the guy I bought it from, then I pulled it about 30 miles out from home and back wth my 20 hp bolens mower in it.Lincoln 225 ac (my first machine)farmhand 115vac 70amp mig/fc toymiller aead 200le (my main machine)
GMT+8, 2025-12-30 07:16 , Processed in 0.103241 second(s), 18 queries .
