how much does the ar 300cyl wiegh full and empty..i got 135 from airgas but didnt know if it was full or empty. the gas goes 34lbsim tired of lifting them onto the cart..that 8'' is a killer...what about an ox300 cyl...bout the same as ar in thier site but i wanna know what it weighs emptythe 35lbs of gas either way is too much to disregard
Reply:Does the weight matter? Sounds like it's more than you want to lift full or empty. Find a way to lift it.Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:well yeah it matters to my boss when my nuts hit the floor....curiosity ever get the best of ya man?
Reply:Originally Posted by dieselbeef....curiosity ever get the best of ya man?
Reply:haaha..other stuff too..so i know its too friggin heavy..so how can i lift it..bossman says use the cap. weld w ring on it..use our overhead hoist....i dont think using the threads to lift it is a good idea,what is the corporate safety way of doing it
Reply:I hug my 330cf like a bear and put it where I want it (once I have it close to where it is going). Squat and use your legs.135lbs empty.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:nah..pepsico dont want us lifting them anymore...gotta be safe dontchaknow
Reply:Use a ramp?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:I do the same thing as gravel. U gota pull up your sleeves or where a t shirt or it will slip out of your arms. Your skin will grip it
Reply:Originally Posted by dieselbeefhaaha..other stuff too..so i know its too friggin heavy..so how can i lift it..bossman says use the cap. weld w ring on it..use our overhead hoist....i dont think using the threads to lift it is a good idea,what is the corporate safety way of doing it
Reply:Could you build a lift that holds the cylinder with a ratchet strap and uses a bottle jack for the lifting?Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Tare weight should be stamped on every cylinder
Reply:Here are a few:(there are a ton)https://www.google.com/search?q=weld...sling&imgdii=_Last edited by MinnesotaDave; 03-11-2015 at 02:33 PM.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday. |
