Welding breaker bar
发表于 2021-8-31 22:41:29 | 显示全部楼层 |阅读模式
My Dad bought this stupid breaker bar for use on his van.it is angled out, they tried using it today andas expected the angle causes the socket to slip and damage the nut.I am wondering if it can be cut and welded back straight 90,are these typically chromoly and what electrodes would work on this if possible ?thanks,LMM 180
Reply:Spend the 20$ and get what you need.Not weld failure in the middle of nowhere......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Good 4 way lug wrench is only about 12 bucks. Way more leverageMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:If you want to use it.. Heat and bendAirco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Originally Posted by SquirmyPugIf you want to use it.. Heat and bend
Reply:312..Welding/Fab Pics: www.UtahWeld.com
Reply:None of those lug nut wrenches really work well with both hands on one end. They all really need support at the angle end. Add the flop of the socket fitting and it goes downhill from there. Some that fit real good you can get by with it in a pinch. The rare good one you might sneak by with jumping on it if there wasn't any other way and you feel stranded otherwise. The cheaper the worse. Some are worthless out of the box."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:What will it cost you when the welded tool fails after you get out of cell phone range?I offer three choices: Good, Fast, & Cheap. You may pick two.Hobart AC/DC StikMate LXHarbor Freight AD HoodHarbor Freight Industrial Chop SawDeVilbis 20 Gallon, 5 HP Compressor
Reply:I would heat and bend that wrench before I cut and weld it.I bought 4 ways for the wife and daughters cars, then taught them to use the jack to hold the end of the 4 way up so they can stand on the cross of the wrench to break the nuts loose. Then put the jack under the vehicle to pick it up! Retighten the same way!
Reply:I like using a swivel head breaker bar.  Bought a couple cheap 3/4 inch breaker bars and sockets that I keep one in the truck and one in the trailer.  Since the head swivels it can be kept at a 90 degree to the lugs for cracking them loose, then straight out and spin them like a screwdriver to remove the lug nuts.    Thinking I might so the same with a 1/2 inch breaker bar in the car.  Got a couple on clearance for $12 each.Last edited by bead-boy; 03-11-2015 at 12:19 PM.Century buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:Why not just make your own heavy duty one. Is it for lug nuts?
Reply:A lot of fear about welding this on here, gees, you'd think those nuts would be torqued to about 3000 lbs.!  I'd go for it, if you have the time to spare............or maybe file a flight plan, in case you are out of cell phone range.......
Reply:Originally Posted by BrianCA lot of fear about welding this on here, gees, you'd think those nuts would be torqued to about 3000 lbs.!  I'd go for it, if you have the time to spare............or maybe file a flight plan, in case you are out of cell phone range.......
Reply:Originally Posted by SquirmyPugFor me there is no fear of failure. I just wouldn't waste my time cutting and welding it when i could heat/bend and be done in 5 minutes.
Reply:I have one that looks pretty much like that, but it has the socket welded on it (from factory). So far it has never slipped on me and the cool thing is that I also carry a 3feet tube to get more leverage. 4 way wrench may be even better (don't know) but I have the feeling that using a breaker bar could be more dificult, plus it takes more room on my trunk.I would suggest just welding the appropiate socket to the wrench as is. The angle is needed for clearance.
Reply:Sometimes you just have to buy good tools. Throw that in the garbage and save the rubber grip for another project. LOL how much you wanna bet the glue on the grip is stronger than that whole Harbor Farter. Last edited by weldermike; 03-12-2015 at 06:42 PM.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by drujinin... I bought 4 ways for the wife and daughters cars, then taught them to use the jack to hold the end of the 4 way up so they can stand on the cross of the wrench to break the nuts loose. Then put the jack under the vehicle to pick it up! Retighten the same way!
Reply:4 ways break too. I recently helped a guy out who snapped one. I was drunk and he was Russian LOL great combo, drunk cherades and he was very thankful lol.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I am confused as to why it does not work as is.
Reply:Originally Posted by weldermikeSometimes you just have to buy good tools. Throw that in the garbage and save the rubber grip for another project. LOL how much you wanna bet the glue on the grip is stronger than that whole Harbor Farter.
Reply:Use one hand on the socket end and it should work better. I would definitely heat/bend before cutting though.  Originally Posted by weldermikeThrow that in the garbage and save the rubber grip for another project.
Reply:Originally Posted by MinnesotaDaveHarbor Farter??  That's what I should call what happens an hour after I eat Chinese Drunk charades with a very thankful Russian woman makes for a better story
Reply:I could deal with what it started out like for ten years. That is why you only bother with women 15 years younger than you are at my age. Unless she falls in a vat of acid she is always going to look better than me. She will still have strength enough to change out my nappies too in a few years.Last edited by mikecwik; 03-12-2015 at 10:09 PM.
Reply:It's a lot like how TV makes all lesbians look super hot and pretty, when in fact, most of them look like Janet Reno.(No, I didn't make that up either, but in thought is was funny and true at the same time )Expert Garage Hack....https://www.facebook.com/steven.webber.948Originally Posted by mikecwikI could deal with what it started out like for ten years. That is why you only bother with women 15 years younger than you are at my age. Unless she falls in a vat of acid she is always going to look better than me. She will still have strength enough to change out my nappies too in a few years.
Reply:Originally Posted by mikecwikI could deal with what it started out like for ten years. That is why you only bother with women 15 years younger than you are at my age. Unless she falls in a vat of acid she is always going to look better than me. She will still have strength enough to change out my nappies too in a few years.
Reply:Originally Posted by labparamourYou make a good point. As I get older I'm less about looks and more about functionality so, maybe the old Russian gal is best...can help unload steel now and lift me on/off the toilet in a few more years.
GMT+8, 2025-12-30 07:17 , Processed in 0.100039 second(s), 18 queries .
