stuck on high idle
发表于 2021-8-31 22:41:26 | 显示全部楼层 |阅读模式
i have a thermal arc gas drive 270 amp.  i am a welder by trade and also do many side jobs.  well i was welding this morning and all of a sudden it got stuck on high idle and now wont weld.  any ideas on what may cause this to happen and why it wont weld being stuck on high idle???
Reply:Would that be as in a Predator?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:There's not enough information here to answer your question. Typing in "thermal arc 270" at the Thermadyne website has multiple hits as to what documents are relevant to what machine.Go here and see if it's there: http://www.thermadyne.com/thermalarc...&Search=SearchOnly when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:i'd check the linkage to the solenoid that controls the idle ( at the engine) and then the wire connections  to the pc board that controls it. Maybe something came loose, or if not that might be a problem with the control board
GMT+8, 2025-12-30 07:17 , Processed in 0.111753 second(s), 18 queries .
