Pulsed MIG.........
发表于 2021-8-31 22:41:25 | 显示全部楼层 |阅读模式
This semester I'm taking the MIG class.....I've never really liked MIG.... I prefer TIG.... and I like Stick a lot........ MIG... not so much.....HOWEVER....... tonight I was introduced to Pulsed MIG for the first time..... the instructor didn't actually know how to set the machine......... so he asked another [very good] instructor.......10 minutes later.... on the Lincoln 350P, setting 14 for .035 wire..... and I was off to the races......I can say publicly.......... that as of tonight...... I officially like MIG........I didn't take pics.... ran out of time.......Now I need another darn machine.........     Precision TIG 185 and MP 210Bobcat 225NTCutmaster 42O/A tanks.... 2 Argon tanks...... 2 C25 TanksFacebook...... F2 Metal WorksETSY....... https://www.etsy.com/shop/F2MetalWorksF2MetalWorks.com....... http://www.f2metalworks.com/
Reply:I started using pulse a couple of years back and like it a lot better than without, when going back to a conventional machine...it's different to say the least....Mike
Reply:wait until you start doing aluminum to see the full advantages of pulsed mig. my old boss can do an outside corner on .060 al with one of his 350mpa's that most guys would swear was tigged.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Yep when you set it right it welds great. But the problem is that poor penetration and porosity are often present. It has its range of usabilility. Very usable for thin aluminium to the point where you can use spray transfer. Also great for brazing with CuSi wire.
Reply:So does pulse mig work well on steel? I thought it's main advantage was aluminum. Pics?!?!?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:http://www.lincolnelectric.com/asset...ture/nx280.pdfMetal core is where it can really shine. I liked using Rapid-arc over pulse or standard spray. Less undercut, and mainly helps on crater control at the end of the weld. Never really used standard pulse with my C-300, and always went with the rapid arc. Sold that machine, and now just use quality dual-shield for most spray applications. Main point, there is always some work around for most things. It just allows more flexibility to have all the high tech waveforms.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Yeah, Rapid arc is pretty neat, like a f***in' caulk gun for steel.  A bit more spatter than standard pulse modes, though.Pulse MIG is good for steel in some ways- thinner sheet, out-of-position welds, minimizing spatter. No major advantage for steel thicker than 1/8" in most cases.Most welds done with pulse can be done with a standard MIG with 75/25 gas if the machine is dialed in properly. Pulse just makes it easier, especially on complex jobs where settings need to be changed often. Not a magic elixir, just another useful tool. JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:Originally Posted by Silicon-basedYeah, Rapid arc is pretty neat, like a f***in' caulk gun for steel.  A bit more spatter than standard pulse modes, though.Pulse MIG is good for steel in some ways- thinner sheet, out-of-position welds, minimizing spatter. No major advantage for steel thicker than 1/8" in most cases.Most welds done with pulse can be done with a standard MIG with 75/25 gas if the machine is dialed in properly. Pulse just makes it easier, especially on complex jobs where settings need to be changed often. Not a magic elixir, just another useful tool. John
Reply:Dont mix fronius CMT or CMT pulse with normal pulse mig.
Reply:I need them guys to make me a new dog brush.........Last edited by B_C; 10-07-2013 at 06:30 PM.  Miller Dynasty 350Twenty Six HammersThree Crow BarsBig Rock
GMT+8, 2025-12-30 07:16 , Processed in 0.116595 second(s), 18 queries .
