查看: 13|回复: 0
Nr232
发表于 2021-8-31 22:41:23 | 显示全部楼层 |阅读模式
I am running NR232 vertical today at school. I am using an idealarc r3s with a LN 25 feeder on 3/8 hrs fillet. I am progressing fine, I am just looking for any tips you might have.2 invision 456 mp, 456 pheonix, 3 hypertherm 1250, Hypertherm 45,Dynasty 200dx, Millermatic 210 w/ spoolgun, Bobcat 250, 12vs extreme, slugger dry cut saw, slugger mag drill, O/A rig, Piles of tools
Reply:Build a shelf, point the gun slightly down, keep the correct stickout.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:if you do a search here theres some advice.     Don't try to weave just do strait up stringers, watch your slag shelf more than your puddle if it starts to form a V try and do a little tiny wiggle to get it flat across.If you think you need to turn it down thats when you actually need to turn it up.   it takes some practice to get the feel for it.Last edited by Dualie; 10-12-2013 at 03:11 AM.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-30 10:01 , Processed in 0.084275 second(s), 18 queries .
