Welding Positioner FS
发表于 2021-8-31 22:41:22 | 显示全部楼层 |阅读模式
Welding positioner for sale. It has a 12" chuck and an air operated foot valve to spin the positioner. It tilts side to side. Stands over 48" high. Can't find any type of manufacturer or serial # on it. Is a very heavy nicely made piece of equipment. Looks almost new. As far as history - the unit is over 20 years old and has very little use. Selling for a friend. $1300 Located by Pittsburgh, PA. Call Bill 412 279-1965 home, 412 496-0619 cell. Email: [email protected] Attached Images
Reply:Positioner is sold
Reply:I have ,& will sell , a 1978 Ford F-350 with a heavy steel bed , on it is a really good running Lincoln SA-250 diesel welder. Paint faded, but runs great ,  welds great. The welder also has installed , a Constant voltage box. I once ran a LN25 off it . Truck needs new master cylinder , and vacuum booster, but I have them in a box, never got around to  changing them . I also installed a hose to oil pan on diesel engine to a rear tool box in bed , so you just place drain pan inside the tool box and crack the quick open valve to drain oil. The welder ,i bought NEW in 1981 , has about 3000 hours on it (just broke in ! ) Might be a real good (first)  rig  for a refinery (pipe) welder. IN San Francisco  Bay Area.[SIZE="5"Yardbird"
GMT+8, 2025-12-30 10:01 , Processed in 0.100802 second(s), 18 queries .
