Spanning Time - Quick Tool Modification
发表于 2021-8-31 22:41:17 | 显示全部楼层 |阅读模式
Working on a job that requires a face pin style spanner wrench or similar type tool to remove/install a couple pieces in the process of rebuilding a diaphragm valve.Could have taken the time to make the entire tool but because I could wait, decided to order a fixed face pin spanner of the proper spacing and pin size from McMaster Carr to use as the basis for a modification instead.  Could have made it a one piece tool with an extension shaft to reach both levels needed to disassemble/assemble the valve but wanted the ability to use what ever length extension (if any) might be required to get any other similar job done.Started with an Armstrong 2" fixed spanner and the cut off female portion of a 3/8" drive Tru-Test extension that has been sitting in my toolbox for years waiting for such a project.Fast forward to the end, the finished product after TIGing with the Syncrowave 180 SD, cutting off the handle and contouring the tool at the cut point.Removing/installing the piston guide, shaft and piston just under 1" deep in the valve body.Piston guide, shaft and piston removed.Removing/installing valve seat located approximately 3" inside the valve body.Thanks for looking.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Looks good. When I get to harbor Freight I pick up some of their extensions for cutting up. I have had to make up quite a few special wrenches as well. Serpentine belt tensioners come to mind, Take one of the best things they ever came up with as far as a tensioner and then pot it so you cant acces it , Got to love it.Miller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:Ha, you just made a 'crows foot spanner'.. "The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:looking was a pleasure, thank's for sharing Q: both parts were probably tool steel, what filler did you use?  Not having a tig i would probably stick weld it with stainless 308-309 or 316 do you think i'm ok?
Reply:Nice one Duane.
Reply:I like it - built tools are always interesting Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Thanks snowbird. Originally Posted by snowbirdQ: both parts were probably tool steel, what filler did you use?
Reply:Hey, duane55,Nice mod, nice photos, but... I cannot grasp how the tool functions.  Can you help me out?  Thanks.
Reply:Here is a link to the original tool showing the pin side.http://www.mcmaster.com/#5480a15/=pyk5nm
Reply:Originally Posted by WeldordieHey, duane55,Nice mod, nice photos, but... I cannot grasp how the tool functions.  Can you help me out?  Thanks.
Reply:Hi Duane, tool looks store bought to me.  Nice job!   Bob
Reply:Originally Posted by DetailerDaveHere is a link to the original tool showing the pin side.http://www.mcmaster.com/#5480a15/=pyk5nm
Reply:Heck, I knew what you were making and still had to think about it. Because I couldn't see the holes or the pins. hahahahLincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:If you were gonna order the fixed pin spanner, couldn't you just order what you made? The product manufacturer must need the same tool for assembly and repairs????Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2025-12-30 08:00 , Processed in 0.104443 second(s), 18 queries .
