Weldng Table Build
发表于 2021-8-31 22:41:17 | 显示全部楼层 |阅读模式
Been getting enough business now that I need a real welding table... It's ~ 3ft x 7ft and will have a 3/8" top when i'm done! Going to plasma it down to size Monday. Once that is done I'm going to do a bunch of measuring, and I want to cut "X" slots on two sides of the table so I can use some of those Miller ArcStation clamps on it.
Reply:I like it! Keep posting pictures of your progress. I need good ideas.
Reply:Originally Posted by tackitlooks like a good start, R U gonna have an expanded metal shelf?
Reply:Love the Arc Station, have one, don't know how I lived without it.While you are in the build stage consider trailer hitch inserts on at five locations.  Two at each end and one in the middle.  Then you can attach tools to the male inserts.  I have this kind of set up on my truck and it is great for vises, benders, notchers.  I also have a killer work bench that weighs at least 800 lbs and I use the same tools on it.Oh, one other thing, there are two kinds of welding table nuts, one assumes tacking projects to the table is proper and then there is the weirdos who don't see it that way.life is good
Reply:Originally Posted by wroughtn_harvLove the Arc Station, have one, don't know how I lived without it.While you are in the build stage consider trailer hitch inserts on at five locations.  Two at each end and one in the middle.  Then you can attach tools to the male inserts.  I have this kind of set up on my truck and it is great for vises, benders, notchers.  I also have a killer work bench that weighs at least 800 lbs and I use the same tools on it.Oh, one other thing, there are two kinds of welding table nuts, one assumes tacking projects to the table is proper and then there is the weirdos who don't see it that way.
Reply:Table top is on! She's done for a couple days... going to put a new garage door on the shop! Yippy!
Reply:That turned out really nice. Sturdy and functional.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Thanks!! I'm pretty pleased with how it turned out!
Reply:looks good!! What part of Nebraska you from?
Reply:Originally Posted by nallbrightlooks good!! What part of Nebraska you from?
Reply:Yeah! here is my take on the the Miller arcstation x table!
Reply:Originally Posted by nallbrightYeah! here is my take on the the Miller arcstation x table!
Reply:i also made a solid top one too
Reply:Damn good lookin' table.-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Tell us how you cut the slots. Sent from my SAMSUNG-SGH-I337 using TapatalkRegards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Im curious to what you paid for the 3/8 plate. A steel shop here quoted me like 500 for a 3x4ft pc. Whilst the 1/4 of same dimension was under 200not sure but maybe he keyed something in the computer wrongMiller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:i paid 120 for both my 30x 30 of 3/8 and they didnt even cut them straight
Reply:Originally Posted by Robert HallTell us how you cut the slots. Sent from my SAMSUNG-SGH-I337 using Tapatalk
Reply:Originally Posted by chevydylIm curious to what you paid for the 3/8 plate. A steel shop here quoted me like 500 for a 3x4ft pc. Whilst the 1/4 of same dimension was under 200not sure but maybe he keyed something in the computer wrong
Reply:Hmmm I willhave to check around but here in alaska theres not awhole lot of options. Thanks thats a nice start to your tableMiller Syncrowave 210 w/CK FlexLoc 150  3/6/14ESAB PCM 1125 Plasma CutterAtlas 12x36 LatheACER 9x42 3hp millHarig 612 Surface GrinderDRINK Machine              welding&fabrication
Reply:Originally Posted by TSCGG13Looks good! I was debating the exact same thing!
GMT+8, 2025-12-30 10:01 , Processed in 0.091327 second(s), 18 queries .
