Fixture table talk
发表于 2021-8-31 22:41:15 | 显示全部楼层 |阅读模式
So recently got into doing some exhaust work, downpipes work and things like that. I'm having a real mother of a time getting these pieces with crazy bends to stay still while I do some welding on them. Was thinking about this cheap table from eastwoodhttp://www.eastwood.com/eastwood-set...ing-table.htmlhowever everything I see seems to be small tube or square in a frame shape. Does anyone have anything or are there kits for these that can hold say a 4 foot or longer piece of pipe vertically upright then have some supports to where it will hold it in place?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:I just use a piece of 80/20 15x15mm t slotted aluminum barI have a holy table and just bolt it verticallyYou could do somethign similar with a piece of angle iron or square tube, just weld on a bolt or drill and tap a hole for quick removal.
Reply:Originally Posted by AluminumWelderI just use a piece of 80/20 15x15mm t slotted aluminum barI have a holy table and just bolt it verticallyYou could do somethign similar with a piece of angle iron or square tube, just weld on a bolt or drill and tap a hole for quick removal.
Reply:i just have 5'x18'  1' thick  plate table and weld uprights and clamp accordingly.   when the jobs over cut the uprights loose and clean the table back flat.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I would build a universal style vertical tube holding jig. Meaning a piece of ~1" channel welded vertically to a ~3/16" plate using clamps to hold it down from there like previously stated. This way you can throw this fixture up on a table, clamp it down, and get to work and when you're done just throw it back in the corner of the garageEdit: I found a picture on my phone of an example I did at work for a fender mount on a 53 ft connex trailer but I have no clue how to upload it, and I'm typing this from my iPhone currently too.Last edited by WeldOnTopOfSlag; 03-15-2015 at 12:26 AM.Reason: Additional comment
Reply:http://www.ebay.com/sch/i.html?_odkw...Text=&_sacat=0you can get aluminum extrusion like this on ebay 24" or 48" longjust tap the ends and bolt it to your tableLast edited by AluminumWelder; 03-15-2015 at 09:00 AM.
GMT+8, 2025-12-30 08:01 , Processed in 0.071758 second(s), 18 queries .
