i need a diagram
发表于 2021-8-31 22:41:13 | 显示全部楼层 |阅读模式
i picked up a hobart 625i plasma cutter and the internal filter/dryer is leaking out of the white hose on the bottom.  i need a diagram so i can make sure it is assembled correctly.  any help with this will be extremely welcome.  i can't set the air pressure correctly and i believe this is my problem.  thanksjames
Reply:James, I assume you tried the Hobart Website.http://www.hobartwelders.com/service/owners-manuals/City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:i saw the diagram, but it doesn't show how the filter is in pieces.
GMT+8, 2025-12-30 10:01 , Processed in 0.100637 second(s), 18 queries .
