anyone use a powercon 200sm before?
发表于 2021-8-31 22:41:10 | 显示全部楼层 |阅读模式
i was given a powercon 200sm today, im not home yet to try it to see if it works yet but figured id see if anyone here has used one and if they liked how it runs. one i got came with a scratch start tig setupCentury 88amp 110v migCentury 100, 110migPowcon200smThermal Arc 140 migThermal Arc Fabricator 211i
Reply:yep, they were the first commercially viable inverters.    at last count i have 8 of them.   but slowly phasing them out as support for them turned to crap and moved across the country.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:I had one for a while, never welded with it but to make sure it worked when I bought it, doubled my money on it, great machine
Reply:Powcon made some great machines. I used to run one everyday. I still have one as a back up to my Dynasty 350.  There is no support for them anymore. It's defiantly worth getting running. It's a nice machine when it runs.(Home)Miller Maxstar 152 (sold)MM211/spool gunLincoln AC 225C(Work)Dynasty 350Powcon 300STLincoln SP-175TWeldlodgic AWS150sWeldlodgic AWS300Custom Resistance seam weldersCambridge Vacuum EB weldersI smell something burning.
Reply:One of the shops I worked at in Arizona, early 90's, had several of them. I liked using them, and don't remember ever having any trouble with them. Only thing that stands out was guys would run the bottle out, then grab another machine. Then the next one to use it would have to put a new bottle on it. ******** !!!!
Reply:I'm pretty sure I have a manual for it if you need it. PM me if you do.
Reply:I had a couple of them, good machines.  Sent w/ Tapatalk using Swype, pls excuse typos now FreeTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I bought one with the wire feeder in 1998, and sold it in 2004.  It was a hell of a nice machine, but parts were already expensive.  I paid $125 and sold it for $1500.
Reply:One of the best welders (stick) I ever used.  Had one at work but it died and the company scrapped it afaik."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:sounds like i might like it, it  came with a tig setup as well...i dont suppose its HF start for tig? and  i assume its a dc only welder as well?Century 88amp 110v migCentury 100, 110migPowcon200smThermal Arc 140 migThermal Arc Fabricator 211i
Reply:Originally Posted by dpaschsounds like i might like it, it  came with a tig setup as well...i dont suppose its HF start for tig? and  i assume its a dc only welder as well?
Reply:Originally Posted by copeDC Only.  Can't comment on the Tig set up.  Does it have the wire feeder?  As norite said, it has an awesome stick mode.
GMT+8, 2025-12-30 08:00 , Processed in 0.081935 second(s), 18 queries .
