查看: 13|回复: 0
Oxygen concentrator
发表于 2021-8-31 22:41:10 | 显示全部楼层 |阅读模式
I tried the search function first, but came up empty.  There's one for sale by me for a reasonable price.  It appears to put out up to 7 liters per minute.  Has anyone used one on a oxypropane torch?I have to do the Math on CFH to LPM conversion, but I'm also worried about the pressure it's supplied at.  Thanks.TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:They run at a pretty low pressure, You might be able to use it to feed a small compressor that could bump up the pressure, like an air brush compressor.
Reply:You do not want to be compressing oxygen with a compressor not made for the job (even an oil-less airbrush compressor).The output pressure will be 3-5PSI.  Flow rate is pretty low.  They're often used with torches, but are not going to be usable with a cutting torch.
Reply:HI, that topic has interested me for a while.......I think you could use one of those peristaltic type compressors to bump up the pressure.They work by squeezing a rubber tube with rollers on a wheel.........this allows the contents, whatever, to be moved without gumming up the works or getting moving parts full of whatever you're pumping.You could also make a gasometer, where you have a container like a bucket upside down in another bigger container the right way up like a bigger bucket, and have water surrounding the bottom.The gas is fed into the inner container and tries to lift the bucket up out of the water or push the water out by the increasing pressure.The atmospheric pressure is approx. 15 psi, so that is the max pressure you can get to.Avoid any contact with oil or grease as the oxygen will support spontaneous combustion and you'll get a big bang.Ian.
Reply:Originally Posted by rlitmanYou do not want to be compressing oxygen with a compressor not made for the job (even an oil-less airbrush compressor).The output pressure will be 3-5PSI.  Flow rate is pretty low.  They're often used with torches, but are not going to be usable with a cutting torch.
Reply:A friend of mine uses one for his torch but it doesn't produce enough pressure for cutting.  Just heating.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-30 09:52 , Processed in 0.110877 second(s), 18 queries .
