查看: 13|回复: 0
Can Anyone Use Some Anchor Blocks?
发表于 2021-8-31 22:41:06 | 显示全部楼层 |阅读模式
We take these off the Cat drivers used on our portable pumps and I have a number of them because I just can't stand to see stuff such as this get the 'deep six'.  Blocks are 1-1/2" square x 4-3/4" long and bolts are 7/8" x 3" coarse thread 'CAT' grade (better than grade 8) with flat washer.If interested, PM me the desired quantity and an address and I'll get your shipping only cost.  USPS Flat Rate Box rates range from $4.95(small) to $13.95(large) plus tax as an example http://shop.usps.com/webapp/wcs/stor...tegoryId=13359.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Even the CAT washers are better They have their own part #.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Well that was quick.  It appears I may be temporarily 'out of stock' on these.If you're still interested in some go ahead and PM your info to me as there will be more in the future.  It'll be treated as a first come - first served basis.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-30 09:53 , Processed in 0.097420 second(s), 18 queries .
