sa 250 in a 2000 chevy 3500
发表于 2021-8-31 22:41:05 | 显示全部楼层 |阅读模式
im wanting to know if anyone out there has ever put an sa 250 sideways, the machine measures 67" and the flanges on the truck measure 63.5" inside to insideI could shorten up the machine a bit but I think I would still have to knock some off the the truck bed flanges.. any suggestion would be appreciated.
Reply:I've seen it done but you have to cut out inside the bedside for the exciter not the rail.Miller trailblazer301gLincoln sa200Miller251Miller spectrum 625Victor oxy-acc2002 Chevy duramax 3500 dually 4x4
Reply:Consider mounting it length wise with the truck rather than sideways, or build a welding bed to replace the factory bed.
Reply:you have to cut the flanges of the bed, the sa 250 is 67" and a rectangle, the inside of the flanges measure 63.5"time is an issue for me or I would build a bed, my 99 chevy with a 300 rediarc has to go to the doctors asap, that's why im looking at getting it done as quick as possible... I welded with an old boy about 15 years ago had damn near the identical rig and sa 250 sideways, but I don't have his # haven't talked with him in years...
Reply:Im in the same boat putting a SA250 in the bed Horizontally of a Dodge 2500.  It Should Just Fit!Where in NEPA are you??Some Blue , Some Red & Some GreyProverbs 16:2-3.2 "All a person’s ways seem pure to them, but motives are weighed by the Lord. 3 Commit to the Lord whatever you do, and he will establish your plans."
Reply:instead of cutting up yalls truck, in my opinion its better to shorten your machine.
Reply:Originally Posted by gto_welder01instead of cutting up yalls truck, in my opinion its better to shorten your machine.
Reply:im up in Susquehanna pa...I thought of shortening it up, but the best I can get is exactly what the inside of the bed rails measure.. that's 63.5" that's about what the end of that armature to the radiator measures so im probably just gonna whack some out of the bed rails..
Reply:You cut the rails and set it down inside and you will have heating problems.  Most of your rad will be below the rail.  Just my $.02 worth.1938 Lincoln SA 600 1973 Lincoln SAE 3001984 Lincoln Sa 250DF800 Ford with 10 ton craneVictor and Harris torches.Rolair compressorSouthbend 13" latheAtlas Mill
Reply:Cut the body, truck is only a big tool box.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Don't Cut the Body! You can shorten the machine to fit between the bed rails. Takes a full day but comes out sweet. I've done 4 myself and just finished one for a friend. The machine runs fine with no cooling issues. The only problem is checking the oil thru the rear sliding window. Sent from my DROID RAZR using TapatalkLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:Got any pics Adam? Some of the machine actually mounted in the truck would be cool.
Reply:Check here....http://weldingweb.com/vbb/showthread.php?325661-250D-chopLong after the price is forgotten, the quality will remain.Both of my Poppy's 1954 Short Hoods -Third generation to weld with it and teaching a fourthSA 2## - Bought and sold more than I can remember or care to list, 8 in the shop right now
Reply:Adam, that's one hell of a job you did.. if I had the time and a garage I maybe and I mean MAYBE would get as deep into that old girl as you did..! I gotta say man GOOD JOB!!!
Reply:Trucks are a tool - tools get modified as needed Cut it up is my vote. I've seen a couple come through here that had big cuts in the bed. They were welded up on the cut edges and looked fine. Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:yeah man, im gonna get hacking on it when I get out of the shop... I appreciate the feedback from everyone..
GMT+8, 2025-12-30 08:00 , Processed in 0.073753 second(s), 18 queries .
