Fitting a 10 lb gang box thru a 5 lb door
发表于 2021-8-31 22:41:04 | 显示全部楼层 |阅读模式
How do you fit a 10 lb gang box through a 5 lb door?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:I think I wouldhave cut the door frame out before cutting on that box!
Reply:I thought the final fit up turned out fantastic. The doors shut ever so properly!"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Very nice work! If I had done this it wouldn't look anything like the original.
Reply:Originally Posted by GravelI think I wouldhave cut the door frame out before cutting on that box!
Reply:Originally Posted by GravelVery nice work! If I had done this it wouldn't look anything like the original.
Reply:Originally Posted by Stick-man He would have had to remove 6" on each side of the doorway, because the door and hallway are so narrow.
Reply:for a minute there i thought you were going to use that cut off wheel on the brick wall loli.u.o.e. # 15queens, ny and sunny fla
Reply:How about a breakdown of what you sticked it backtogether with - thanksThe main thing is not to panic or get excited Bobcat 250, X-Treme 12VS,  MM211Meltabo, Milwaukee,Porter Cable,Dewalt,MakitaVictor O/A, Ingersoll-RandEvolution Rage2, 40 amp PlasmaLincoln 225 AC/DC
Reply:The steel plates were just 1/8" x 4" flat, with 1/4" bolts & nuts. I welded it with lift arc off the Commander, 1/16" red, maybe 60A, 15cfh Ar. He didn't want it fully welded, because when this gig slows down I'm gonna have to cut it apart again to remove it. Then I will fully weld it back together. He contemplated having me build a chest from scratch, but it would have costed way more. He got this chest for $400, and he doesn't mind the dents, just functionality."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Nice work. Preparing for a project ?Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:I bet he don't know if he is coming or going!!!!But he does look happy.DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
Reply:This begs the obvious question... How`d they get it in there in the first place?
Reply:would it not have fit if you stood it on end?Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:Nice work. I would have hated to cut up a big buck box like that. I had to cut something like that for a job, Big box small opening. Before cutting I centered flat stock entire length with predrilled holes for bolting on both sides of  cut . Set in place and drill holes in cabinet. Cut and bolted together. Made line up easier.
Reply:Originally Posted by RocketprophetThis begs the obvious question... How`d they get it in there in the first place?
Reply:I think you just described what I did.  For some reason all of the pics didn't show up. Never saw that, sorry. Only the  ones with the welds came in the first time.
GMT+8, 2025-12-30 11:42 , Processed in 0.112551 second(s), 18 queries .
