Ideas for Scrap.....
发表于 2021-8-31 22:41:03 | 显示全部楼层 |阅读模式
I have a few hefty piles of these...These were old shelving units in a bunch of Walgreen stores i picked up for free this past summer..I was mainly after all the Gravity roller tables they gave me for free from several stores as long as i hauled everything off along with them from several stores where they were updating to new equipment...i made a killin on the roller tables..i had a total of 32 section of 10' long heavy duty roller tables..sold them all pretty wuickly for 200.00+ per section..now i have a few of these piles laying on the backside of the property..wonderin what i can build with them to sell or use them for..These just the horizontal railings..there was no vertical legs with them,they must of re-used them with the new rail system..so i can't sell these as shelving units unless i buy some material to make vertical legs..either drilling holes for these or welding them as permanantNone are enclosed tubing..they all have one side open...any ideas??? Attached ImagesLincoln Ranger 8 225Lincoln 180 ProMigMiller Maxstar 200DXInternational Ironworkers Local 70930+ years and counting
Reply:Fencing or some sort of caging?
Reply:benches, heavy duty picnic tables, adorodak chairs, coffee tables, end tables, welding tables, etc. use your imagination.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Dinosaurs. Lots of big lizards.MM210TA186TA95sLincoln AC/DC Tombstonegood old Smith torch setup 24v Readywelder mig w/spoolgunSB H 10 latheBridgeport mill6x12 K.O.Lee surface grinderK.O.Lee tool/cutter grinder
Reply:Originally Posted by ThorsHammerbenches, heavy duty picnic tables, adorodak chairs, coffee tables, end tables, welding tables, etc. use your imagination.
Reply:The open ends only come into play if you don't address them for interior furniture.There are no problems. There are only solutions. It's your duty to determine the right one.Hobart Handler 210Airco 225 Amp MSM Stinger
Reply:Originally Posted by ThorsHammerThe open ends only come into play if you don't address them for interior furniture.
Reply:Fence spikes, Caltrops, hedgehogs.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
GMT+8, 2025-12-30 08:00 , Processed in 0.101935 second(s), 18 queries .
