7018 motion
发表于 2021-8-31 22:41:02 | 显示全部楼层 |阅读模式
Whats yalls favorite motion (circles, weaves, drag or similar motion) for 7018 in all positions?Miller Dialarc 250Miller Bobcat 225Hobart Oxy/FuelCouple of Dewalt and Milwaukee GrindersJET Bandsaw and Drill Press
Reply:Slight side to side.Let your amps do your work for you.Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Never circles, you don't want slag inclusions.
Reply:Yes. Motion I use is dependent on how I want to manipulate the puddle and based on what I see the puddle doing. Different joints lend themselves to different motions, but in reality it's all about manipulating the puddle. For example outside corners tend to lend themselves to straight beads with no motion, or just a slight side to side motion. I find I have to travel too fast most times doing circles to get the nice consistent bead I like. However, push comes to shove I can do it that way if I have to. Vertical up I usually stack layers horizontally, but I can do circles, a V or inverted V or even a figure 8 if need be.I do a demo for students on this. I'll start a flat fillet doing a circular or cursive e motion, then without stopping, transition 1/3rd of the way thru to a Z or C motion, and then again without stopping, finish the last 1/3rd by doing a straight bead with no motion. If I'm on my game that night, you won't be able to tell where I changed motions. If I'm off a bit, you may see a slight hiccup right where I transition from one motion to the next. The main beads themselves all look identical. It's not about the motion, it's about puddle manipulation. Those that limit themselves to motions typically do what I call timing patterns. That makes them 2nd rate welders at best because they seldom can alter their pattern to accommodate changing conditions such as poor fit up. A good welder watches  the puddle and makes changes as needed based on what he sees the puddle doing..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by Welder DaveNever circles, you don't want slag inclusions.
Reply:Originally Posted by farmwelderHaha my mentor used to be a machinist at the shipyard and he always does circles.
Reply:I've seen a lot of extremely good welders and never saw any of them do circles with 7018.
Reply:Originally Posted by DSWYes. Motion I use is dependent on how I want to manipulate the puddle and based on what I see the puddle doing. Different joints lend themselves to different motions, but in reality it's all about manipulating the puddle. For example outside corners tend to lend themselves to straight beads with no motion, or just a slight side to side motion. I find I have to travel too fast most times doing circles to get the nice consistent bead I like. However, push comes to shove I can do it that way if I have to. Vertical up I usually stack layers horizontally, but I can do circles, a V or inverted V or even a figure 8 if need be.I do a demo for students on this. I'll start a flat fillet doing a circular or cursive e motion, then without stopping, transition 1/3rd of the way thru to a Z or C motion, and then again without stopping, finish the last 1/3rd by doing a straight bead with no motion. If I'm on my game that night, you won't be able to tell where I changed motions. If I'm off a bit, you may see a slight hiccup right where I transition from one motion to the next. The main beads themselves all look identical. It's not about the motion, it's about puddle manipulation. Those that limit themselves to motions typically do what I call timing patterns. That makes them 2nd rate welders at best because they seldom can alter their pattern to accommodate changing conditions such as poor fit up. A good welder watches  the puddle and makes changes as needed based on what he sees the puddle doing.
Reply:my vote would be never circles.    if you guys can do it, and xray, your one or more up on me.   Slag entrappment would be the first thing to cross my mind also.   I just couldn't imagine being able to control or fight the slag.
Reply:Originally Posted by farmwelderWhats yalls favorite motion (circles, weaves, drag or similar motion) for 7018 in all positions?
Reply:My background is X-ray spec pipe welding and I've never seen anything but side to side weave or stringers.  On structural fillets you can do whatever you want.
GMT+8, 2025-12-30 08:01 , Processed in 0.073726 second(s), 18 queries .
