Helium Tanks
发表于 2021-8-31 22:41:00 | 显示全部楼层 |阅读模式
Can helium tanks be repurposed for anything other than helium?
Reply:Yes,  you can have then files with any inert welding gas.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I assume you are talking about standard welding cylinders vs the cheap freon style cylinders used for balloons. If it's a welding cylinder than yes you can typically get it filled with any inert gas, though most places simply exchange vs fill. My place will swap and similar sized cylinder for any other gas.The cheap balloon cylinders can be repourposed for small grills or forges..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Helium, argon, nitrogen, and C-25 cylinders have CGA-580 valves, so there is some interchangeability there.
GMT+8, 2025-12-30 08:01 , Processed in 0.114863 second(s), 18 queries .
