CK Tig torch compatibility?
发表于 2021-8-31 22:41:00 | 显示全部楼层 |阅读模式
Does anyone know if a CK17 is the same cable fitting as a WP17, got someone selling a CK17 1 piece cable and I have been wanting to switch to a 1 piece cable lately, I have a wp-17 2 piece cable.Miller Maxstar 200 SDPiperliner #10 Gold
Reply:I am confused on your question. On the torch side they are the same. On the opposite (machine) side, there are a couple fittings that may be on the end. There is the larger fitting commonly seen on two-piece cables that fit directly into the regulator on an Argon bottle. There is alternatively the smaller fitting commonly seen on the end of single line rigs which is inserted into a "power block" adapter. CK makes allot of different styles, and it is hard to say definitively. The amount of fittings and thread styles being used is mind boggling, it drives me up the wall.Constant Current Weldor.
Reply:Picture is worth a thousand wordswww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Torch end, Im asking if the fitting is the same on the torch end not the power block end. David answered it for me.Miller Maxstar 200 SDPiperliner #10 Gold
GMT+8, 2025-12-30 10:01 , Processed in 0.096651 second(s), 18 queries .
