Good auction find
发表于 2021-8-31 22:40:57 | 显示全部楼层 |阅读模式
Went to an auction down the street from us and came back with this for $25. Pump's empty so don't know if it works at all. Hope so because it has the double piston set up, one large dia for speed and one small dia for the push. The ram looks like maybe 15 ton at least. I'll piddle with it sometime when there's time. Don't need a press very often but when you need it, it's good it's there waiting. I figure I got more than my money's worth in iron.                 MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Looks like the 40 ton the local machine shop has.My name's not Jim....
Reply:It appears to be a hand operated  press. Did you check the oil level in the tank? If oil level is good and handle pumps its possibily a bad O ring sealThere may also be a filter screen in the oil tank that is pluggedLast edited by specter; 02-27-2010 at 07:28 PM.Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
GMT+8, 2025-12-30 08:57 , Processed in 0.102691 second(s), 18 queries .
