Robot Welding Vertical up
发表于 2021-8-31 22:40:54 | 显示全部楼层 |阅读模式
Hi,  I thought this an interesting concept,  If a Robot was doing vertical up welding it would it would      move quickly back an forth  an pushing the puddle up at the same time,  I tried this, an it seems to     work.  "Well sort off". I just wondered what everyone thinks?  esp.DSW.  Thanks, Josey
Reply:Most of the robots I have seen welding were using hot short circuit or spray transfer mig. If they needed to weld vertical I would think they would be using pulse to help control the puddle and doing a slight weave to keep the bead flat and wetting at the toes. Why would a robot weld vertical? Just have the part on a positioner to work with the robot and watch it weld really fast. Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
GMT+8, 2025-12-30 08:48 , Processed in 0.142547 second(s), 18 queries .
