Help critique shedule 10 304ss tig
发表于 2021-8-31 22:40:54 | 显示全部楼层 |阅读模式
Its been a while since my last shed10 critique (4 years or 5).100a peddled down to 90a I estimate1/16 e3 tungsten #8 cup, no lens (I know) 14cfh argonAny pointers? I am not the best yet at steady speed... But I'm welding daily to work on it. Matt Attached Images
Reply:To hot, try 75-85Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Even with a purge? This just gets into the base with a hard edgeSent from my SGH-I317M using Tapatalk now Free
Reply:Amperage looks fine to me, like you said in your post work on keeping a steady speed Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:Thanks. I have a gas lens on order too. Lws didn't have any in stock. Sent from my SGH-I317M using Tapatalk Last edited by zapster; 10-18-2013 at 10:25 AM.
Reply:Originally Posted by SquirmyPugAmperage looks fine to me, like you said in your post work on keeping a steady speed
Reply:Looks ok. Maybe move a bit faster.
Reply:Originally Posted by weldermikeAnd torch angle.
Reply:I am glad you asked that question. Reading all of these threads are really helpful. I also need the answer on torch angle.
Reply:Originally Posted by shlammedWhat do you see that gives away the indication of poor torch angle?
Reply:Probably the width of the weld on the topside of the pipe. Looks like you had the torch tilted back a bit at the 12:00 area. Have you tried running about 65-75 amps 100 is way too much imo.
Reply:Thanks. Yes I have tried those amps, but the weld doesn't have enough power to get right down into the root unless I do 2 passes. Sent from my SGH-I317M using Tapatalk
Reply:Originally Posted by vettersjakeI am glad you asked that question. Reading all of these threads are really helpful. I also need the answer on torch angle.
Reply:Sorry not trying to steal your thread
Reply:Originally Posted by shlammedThanks. Yes I have tried those amps, but the weld doesn't have enough power to get right down into the root unless I do 2 passes. Sent from my SGH-I317M using Tapatalk
Reply:What makes it a better option vs using more heat to do it in one pass?Its only ~1/8" wall with a bevel, and its not open root.
Reply:My new CK welding torch came in last night.Unreal difference being back to a quality torch. Rotation of the torch is possible again and the flex head flexes properly.stepped out the back door while the wife was watching TV and made a quick pass on the new setup to put some heat into some tube Although its not shed 10 SS, i think that the china rubber #26 torch that came with my everlast welder was finally becoming a hinderance.  I had a Weldcraft #17 with flex hose on my Lincoln 185 when i sold it and remember the everlast peice being really combersome in comparison.  this #9 superflex is like a whole different ball game!Picture of the pass i made.2.5" butt weld ferrule to 2.5" mild steel tube70A on the main panel, peddled down to ~50a1/16 308L filler#8 gas lens1/16" e3 hybrid tungsten6L/hr (12cfh) argonWeld closeup by HellaFab, on Flickr
Reply:You using a gap? Try around 70amps. Jumbo 10-12 Cup. Torch all the way.
Reply:Razor edge bevel on shed 10. Not using a gap on the 0.065" stuff. Sent from my SGH-I317M using Tapatalk
Reply:I think it looks good. 1st on WeldingWeb to have a scrolling sig! HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
GMT+8, 2025-12-30 09:03 , Processed in 0.072556 second(s), 18 queries .
