Check this guy out !
发表于 2021-8-31 22:40:51 | 显示全部楼层 |阅读模式
http://providence.craigslist.org/wan/1156186976.html
Reply:What a DINK!Millermatic 252"Don't worry, he's got a welder, he can fix anything"
Reply:Somebody should call him!
Reply:The Zapster strikes out on his own?
Reply:This guy graduated barely ahead of Forrest Gump.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I've seen similar on my local craigslist, even guys offering to weld for free just to get practice time. ALmost wondered if welding sudents were told by their teachers to put the adds out to get some time in.
Reply:Someone should call him and ask if he knows anything about  smaw.
Reply:I have a definition, http://www.merriam-webster.com/dictionary/moronGo hot, or go home!
Reply:I think I used to follow that guy around fixing messes, lmao.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:Thats priceless man somebody needs to call him and see if he can fix there kids bicycle or something.1990 SA 200Miller 225  Rip Miller302Miller 135Lincoln 200 MigHypertherm 600 PlasmaPlasma Cam Cutting TableMikita Cold SawJL Welding Tx . com
Reply:hey guys, how did you find my post?
Reply:Money's short. Times are hard. Get a Longevity/ Everlast, and forge your welding card.I'z a poet, and didn't even know it!And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Sounds like a real pro to me...(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Originally Posted by Jolly RogerI think I used to follow that guy around fixing messes, lmao.
Reply:ask him if he can fix a broken heart or the crack of dawnMOLON LAVE
Reply:At least he is showing some initiative. If he survives, he will learn. Hope he doen't kill anyone...     When I was 12 I had a solidox kit of you can remember those. Didn't have power in my chicken coop "shop" Soon moved up.    Ever tried to convince chickens to wear helmets?past work toys; lathes,mills, drills, saws,  robots, lasers ironworker, shears, brake, press, grinders, tensile tester,  torches, tigs, migs, sticks, platten table, positioner,  plasmas , gleeble and spot. Retired June 30, 2009.
Reply:that guy must wear a diaper and safety helmet  !   daye
Reply:The thing about an ad like that is, he's probably covered up with calls to weld. Like wesdavidson said I just hope he doesn't get any one hurt.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
GMT+8, 2025-12-30 08:58 , Processed in 0.071384 second(s), 18 queries .
