Small welding and soldering project
发表于 2021-8-31 22:40:50 | 显示全部楼层 |阅读模式
Needed a scoop to remove ice from fishing hole and had this high carbon wire  salvaged from a futon. It was a little tough getting it bent around a quart paint can,LOL!! Wrapped the screen around the loop and soldered it to the loop, then trimmed off excess w/ the dremel.             MikeAttachment 572431Attachment 572441Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Looks good does it work well
Reply:give a welder some junk and a few minutes and anything's possible. good idea!i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by zachary80Looks good does it work well
Reply:Sounds like the stuff I use.Good use of "junk" looks like it will serve the purpose well.
Reply:The guy from Louisiana sez if you gotta scoop ice from your fishin hole.........It's too damn cold to be fishin. Now I lay me down to sleep, by the bed a Colt I do keep.Should I wake and find you inside, a coroner van is your next ride.
Reply:Originally Posted by phillipThe guy from Louisiana sez if you gotta scoop ice from your fishin hole.........It's too damn cold to be fishin.
Reply:Great job! That's a nice save for a good purpose.PlasmaCam CNC cutterLathe and Band SawClamps
GMT+8, 2025-12-30 08:48 , Processed in 0.081917 second(s), 18 queries .
