hf 80amp inverter weld
发表于 2021-8-31 22:40:48 | 显示全部楼层 |阅读模式
i bought an harbor freight 80amp inverter a couple weeks ago for tinkering around on thinner stuff and also to do scratch start tig. havent got to play around with the tig much but ran some 7014 3/32 rods tonight on 1/8in plate. a little on the colder side, machine only tops out a 80 amps but didnt run too bad for a cheap 120v machine thats good enough for non critical home welding.
Reply:That's a badass little welder.Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:80 amps is at the very bottom of the suggested range for 7014. That little machine really needs to be run with smaller rods or a rod like 6011 that will run at lower amps. If all you want to do is stick metal together it will work, but you really need more power than you get with that little box to run 3/32" rods..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:i have some 1/16 rods too    just seeing what it was capable of  didn't buy it for stick purposes thats what the 240v machines for
GMT+8, 2025-12-30 08:58 , Processed in 0.096752 second(s), 18 queries .
