Sandblaster
发表于 2021-8-31 22:40:44 | 显示全部楼层 |阅读模式
I've got a couple things I want to get done this summer.  Including building a new dump bed for the truck, and stripping and re-shooting the paint on the rear frame.Can anyone suggest an affordable blaster?  I figure the frame would be my biggest project, nothing bigger than that really.
Reply:Rent it. When we swapped bodies on our Mack, we sandblasted the new body, frame, equipment trailer and what ever else we could find that needed it around the shop. We just simply rented a 1050lb pressure pot type blaster and the 185 fcm IR jackhammer compressor to run it from the local rental center. The "kit" had the 150lb or 300 lb pot, the 185IR and 50' of hose, the airflow hood and pump and heavy gloves for $200 a day. We shot every thing in one day. I want to say sand ran $8 a 50lb bag and we probably went thru 150 lbs of sand maybe a bit more.Most small sized pot type sand blasters need a good sized volume of air to run them, usually 15cfm or more at 90+psi. The bigger ones require a big tow behind compressor. Most guys really don't have the air volume to run even the small ones.I'll probably end up renting one to do both the plows this summer and posibly my buddies small trailer and a few other odds and ends. It will probably take longer to set up each piece to shoot than it takes to do it. I doubt everything I plan to do will take more than 2-3 hrs tops, and by doing some of his stuff at the same time we can split the costs and save. Then while I'm running the blaster back, he'll probably set up the spray gun and start shooting everything with primer..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:That's a good idea.  I do have a tow behind compressor for my taking whenever I need it.
Reply:The place near me rents the air hood for $60/day, $24/ 2hrs $8/hr after that.  The air hood is well worth it if they've got one. Keeps your lens from fogging up and you're not clogging masks or filters like no tomorow. The 150lb or 300 lb blaster runs $94/day, $36/ 2hrs $12/hr after that. You'll probably have to get a tip as well, I forget what they cost. If you have everything ready ahead of time you can setup blast and take it back and save some cash if you've got the compresor..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:i went with eastwood sand or soda blaster Attached Images
Reply:I have a cheap plastic hopper gravity feed blaster and it works. I also have a wand to inject sand for use with my pressure washer, I have not used it yet.However, I always wondered how you can go to HF and get a sand blaster for under $200.00 and you look at Northern Tool and a Marco or Schmidt is in the thousands of $. Not knowing much about them, what is the big difference? I mean we are not talking electrical components here like HF v. Miller. Also, would it be difficult to make a pro quality one out of say an old compressor tank?"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Brendon...PM sent.Miller 211Hypertherm PM 451961 Lincoln Idealarc 250HTP 221  True Wisdom only comes from Pain.
Reply:Originally Posted by Stick-manHowever, I always wondered how you can go to HF and get a sand blaster for under $200.00 and you look at Northern Tool and a Marco or Schmidt is in the thousands of $. Not knowing much about them, what is the big difference? I mean we are not talking electrical components here like HF v. Miller. Also, would it be difficult to make a pro quality one out of say an old compressor tank?
Reply:Years ago, I 'built' a pressure tank for sandblasting by modifying an obsolete gas cylinder, and I bought a quality sand hose and valve from TIP Sandblasting Equipment. They had all the related gear but seem not to have a website, and are now out of business, which I just found out!Their Pressure Blasting equipment (and parts for their old valves) is now carried by:Brut Manufacturing Co., 4680 Alabama Avenue S.W. Navarre, Ohio 44662        http://www.brutmfg.com/ Tech Support: 1-888-533-2693     Mon-Thurs: 8am-5pm ESTLast edited by Oldiron2; 03-09-2010 at 11:48 AM.
GMT+8, 2025-12-30 09:52 , Processed in 0.140217 second(s), 18 queries .
