WTB: Miller Bluestar 1E or 2E Pieces or Complete
发表于 2021-8-31 22:40:40 | 显示全部楼层 |阅读模式
I am looking for Miller Bluestar 1E or 2E machines complete or in pieces.I need to put something inexpensive together as money is short !!I am in West Texas south of Lubbock.Thanks !!
Reply:What parts do you need to complete your machine? I have two machines, one complete, and one  tore down, and attempting to rebuild it. Im not sure what all parts I will need, but was just curios what you needed as I may have parts left over.
Reply:Thanks for the reply!I have two 2E machines and am mainly looking for extra parts or a complete machine to keep the other two running.Right now both are in good operating condition, but I am trying to hedge my bet by having a spare or parts on hand just in case.Where are you located and what would you be willing to part with ?
Reply:Well the one that I am in the process of rebuilding (or wanting to rebuild) was a project that I started a long time ago. I bought the other machine which is complete from a welding shop about a year ago and havent had time to take it apart and deal with it. I can send some pictures of both machines if you are interested. Make offer?? or I am open to trades/guns. I live in Wichita Falls Texas. You can email me at [email protected] if you have any questions or want to know about specific parts I can take pictures for you. Thanks
Reply:would one of you guys mind sending me a pic of a working carb linkage so I can fix mine? thanks for any help.
Reply:We should have all parts for the 1E and 2E here.      On the carb picture, which engine do you have? We can send you a picture of operating unit. weldersales
Reply:Miller AEAD 200LE parts wanted Anyone have or know where to get used or discounted part # 071 609 weld/idle card and 081 359 transformer for idle? I bought a used weld/gen. Welds OK but idle surges when in power mode.Thanks.
Reply:We should have what you need for the idle card. On the surge, is your machine old enough to have the vacuum booster on the manifold? Device was about 2 x 3 inches, bolts onto the top of the cast iron manifold, has a 11/2 " lever with a spring that attaches to carb linkage. Its purpose was to eliminate surging. weldersales
Reply:Originally Posted by weldersalesWe should have what you need for the idle card. On the surge, is your machine old enough to have the vacuum booster on the manifold? Device was about 2 x 3 inches, bolts onto the top of the cast iron manifold, has a 11/2 " lever with a spring that attaches to carb linkage. Its purpose was to eliminate surging. weldersales
Reply:I've got a 1E that im looking to get rid of..  it runs great, no problems at all..  Ive gone to mostly mig welding but, i almost want to hold onto it cause these things last forever!
Reply:Hi I have a 2e that was operating an just stopped producing power I replaced the brushes with 24v genorator brushes and I get 110v power but just enough to turn light bulb element orange  any sugestions Please Thankyou Rob
Reply:I have a 2E AC/DC welder.  It is putting out 160volts on the 120volt power plugs.  Any idea what to check next?It appears to be working otherwise.Thanks,Sam
Reply:I need the manifold pipe and gas tank for the Blue Star 1E. Thanks,Matthew
GMT+8, 2025-12-30 09:51 , Processed in 0.167647 second(s), 18 queries .
