Used to the old ways
发表于 2021-8-31 22:40:39 | 显示全部楼层 |阅读模式
Is it possible that I've gotten so comfortable with my 180 Lincoln that when I pick up a "new" more "sophisticated" gun in an inverter machine that I'm just not comfortable and my welds suffer? Sounds like it's probably self-answering but I never know till I ask.
Reply:Welding machines are like cars in that respect. New is "strange". It works the same with women.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:It works the same with women.
Reply:Originally Posted by FarmDadNahh..  Its cheap to trade cars or welders till you get one you like .  Get the wrong woman and you will never really be able to afford another .
Reply:98.5 % of my welding experience has been with engine drives. Never seen an inverter until retiring. First time I used one was a Dynasty. I was just floored at what control they have over the puddle.Best thing since chocolate ice cream! Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:You get used to the machine, Jonathon.I have welded with transformer machines all my life, until recently.  Large, LOUD, transformers!  The cooling fans sound like a P&W R-1380 swinging a Ham Standard at take off.  The first time I welded with a Dynasty the silence was deafening.  Kind of like starting a turbine for the first time.  Instead of the clank, boom, and smoke of the old reliable round motor just a quiet little whine of the thing makes you wonder if it is working.BTW, some sage advice given to me by an old spray pilot when I was just starting out, "If it Floats, Flies, or F^cks, it's cheaper to rent it!"Last edited by Rog02; 10-24-2013 at 10:51 AM.RogerOld, Tired, and GRUMPYSalesman will call, Batteries not included, Assembly is required, and FREE ADVICE IS WORTH EXACTLY WHAT YOU PAY FOR IT!Dial Arc 250HFThunderbolt 225 AC/DCAssorted A/O torches
Reply:Yeah, Rog, I know the FFF rule all-too-well, all-too-personally!!! Thanks to you and the others for the responses. It just doesn't feel right, work the same or give me the same result as my trusty 180 that I learned and am learning with. Maybe I'm just old. I hate change!
Reply:Originally Posted by DSWOnly if you buy rather than rent....
Reply:Since this thread is pretty banged up I'll add that I've got a friend that is going on 50 years married to his childhood sweetheart. He has a couple of sayings.If it has t!ts or wheels sooner or later you're gonna have trouble with it...Good thing they have two sets of lips, one to pi$$ with - one to moan with...Back to topic, yes welders have different personalities, the makers also have different ideas of how the power supply should work - you have to adapt.Good luck,Matt
Reply:Originally Posted by jlamesYeah, Rog, I know the FFF rule all-too-well, all-too-personally!!! Thanks to you and the others for the responses. It just doesn't feel right, work the same or give me the same result as my trusty 180 that I learned and am learning with. Maybe I'm just old. I hate change!
Reply:Having pulled the thread into disarray I will come back and note that there has always been a " learning curve "  to transition between two machines .  No two machines will perform exactly alike even if the they are the same model .  When you pitch  " new technology " into the mix it just increases the differences between what you are used to and what you are working with now .  People are funny , and i am no exception , in the sense that once they " learn " a machine  even an easier or better machine  will tend to be hated until they become accustomed to it . Then by the time they become comfortable with the new old faithful some dammed fool brings them a  new and improved dingus  and the whole cycle starts over  LOL .
GMT+8, 2025-12-30 09:53 , Processed in 0.098884 second(s), 18 queries .
