Water cooled Lincoln invertec 270tp very delayed start/ weak starts
发表于 2021-8-31 22:40:39 | 显示全部楼层 |阅读模式
Hi guys just bought a water cooler and tig torch but I'm struggling to start an arc it's hit and miss at best and very detayed after pressing the foot pedal ( also new foot control)Any ideas? Ground connection is good, seems to be more responsive in pulse modeThanksLincoln v270 T PulseLincoln v270 T Pulse #2Unimig 200 InverterCigweld 170HFThomas Super Technics 350
Reply:are you getting HF at the start ?Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:I have it set to hf start however I have to be very close and there's still a long delay. To think of it I can't hear the hf but it does start without touchingLincoln v270 T PulseLincoln v270 T Pulse #2Unimig 200 InverterCigweld 170HFThomas Super Technics 350
Reply:Further backgroundi had a welding shop make up the tig torch to match my welder its a ( tigmaster size 20) is it possible that they made a loose connection? seems as though the machine is struggling on the power front. It is a long delay if and when it starts and it really struggles in non pulse mode. when i go to let go of the pedal the arc stays on for a long time and wanders a lot.ill post pictures tomorrow of the setupcheersLincoln v270 T PulseLincoln v270 T Pulse #2Unimig 200 InverterCigweld 170HFThomas Super Technics 350
Reply:Is there a crater control feature that got turned on?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Did you have an aircooled torch previously and did it work?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Ive never used this welder before so thats why im running through the options. Im going to try it with a air cooled today. Crater function was turned off
Reply:still no luck ???Miller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:Hey mate, no luck with the air cooled torch. convinced the hf doesnt work. its at the repair shop now as we speak. not looking forward to the outcome could be $$$Lincoln v270 T PulseLincoln v270 T Pulse #2Unimig 200 InverterCigweld 170HFThomas Super Technics 350
GMT+8, 2025-12-30 11:45 , Processed in 0.095523 second(s), 18 queries .
