A quick thank you
发表于 2021-8-31 22:40:38 | 显示全部楼层 |阅读模式
Just wanted to say thanks to all the members that post lots of useful info. I usually learn something evry time I log in. I dont know who first posted the trick of welding a bearing race inside of a blind hole to shrink it out but man is that the cats meow. 2" dia race ran around it with the mig turned it over and race fell right out.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:That's why we're all here, to share knowledge and ideas.                           MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Reply:Hey Farmshop,That sounds like information I need, but I could not find the post you refer to.Can you add a link?Thanks.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Not sure how to post a link. Do a search for shrinking bearing races. I was amazed when I tried it. Have done it up to 4.5 " outter diameter. Just run as hot of bead as you are comfortable with so you dont burn through. Make sure you can control the weld. Dont worry about stops and starts.Millermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
GMT+8, 2025-12-30 11:37 , Processed in 0.120485 second(s), 18 queries .
