Help understanding chart Newbie
发表于 2021-8-31 22:40:38 | 显示全部楼层 |阅读模式
Can someone help me where my settings should start out at?  I'm welding 16 gauge and 18 gauge auto panels.  trying to patch panels.  I forgot to look at my wire size.  Here's the flowmeter i'm using.http://www.ebay.com/itm/220914611673...9#ht_803wt_679
Reply:For 18ga. I would start with .024 wire with 75/25 mix, 20cfh gas flow, electrode positive, voltage 1, wire speed 20, with 1/4" stickout.If your not using gas you will use flux core .030 wire, electrode negative, voltage 1,wire feed speed 1, with 1/4" stickout, according to your chart.
Reply:thx henrymac.  When people say they're using 20 cfm, they really mean 20 cfh?
Reply:Originally Posted by jrockdiddyI forgot to look at my wire size
Reply:Yes I have gas, I'm assuming its co2/argon. Here's a pic. I'll look at wire size when I get home.
Reply:The tank is stamped #15 CO2 but the label says 100% argon.The welding gas supplier is also named on the label. Take the tank by them and ask.If it is 100% argon it won't mig weld steel at all. it is For TIG welding and aluminum mig.Where your label says argon, Mixed gases will be listed and what % of each in the spot.
GMT+8, 2025-12-30 10:02 , Processed in 0.145258 second(s), 18 queries .
