查看: 13|回复: 0
Maxstar 200 SD TIG torch
发表于 2021-8-31 22:40:37 | 显示全部楼层 |阅读模式
I have a Miller Maxstar 200 Sd that I need an Aircooled TIg torch for. I was thinking about a 17 series flex head with the 25 foot cable. What I am confused about is the hookup as far as a 1 or 2 piece cable. I have seen an adapter for the 50 series Dinse with a gas connector, which I believe goes to the front fitting on the machine. How would the cable and hose hookup to this?
Reply:The torch just screws into the Dinse connector. The dinse connector should already have the gas line attached to it. I have a CK17-FX aircooled flex torch and I love it. the cable is one piece as the gas cools the power cable inside. So far the torch itself  it has held up much longer than the weldcraft or weldtec torch. I have not ordered the superflex cable yet as the stock one is doing ok.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:One thing I forgot to ask is what is used to start the gasflow with the contacter.
Reply:Originally Posted by M J DOne thing I forgot to ask is what is used to start the gasflow with the contacter.
Reply:So I need something like the Rcc14 to go to my front 14 pin connector.
Reply:Originally Posted by M J DSo I need something like the Rcc14 to go to my front 14 pin connector.
Reply:Originally Posted by shovelonYes, just like a foot pedal.
Reply:Originally Posted by M J DThanks for the help, I think I understand what I need now.
Reply:Originally Posted by smilexelectricYour gonna love the machine, I have one as well. A 2001 model.
GMT+8, 2025-12-30 11:41 , Processed in 0.185101 second(s), 18 queries .
